Header gaskets for steel against aluminum heads
64 f100
Post by 64 f100 »
What would work best? I've ordered a set of aluminum gaskets that are layered, but have also noticed some stainless made in the same way in layers. Mostly concerned about damage to the heads. What experience have most of you had with this application?
bird55
Re: Header gaskets for steel against aluminum heads
Post by bird55 »
I don't have aluminum heads BUT I have used copper gaskets for my headers. I got them thru FPT in Seatlle although they do not manufacture them. Sorry wish I could recall the contact.
They have worked really well. Not cheap though.
bird55
Post by bird55 »
here's the contact FORD Powertrain Applications.
Phone/Fax: (253) 848-9503
64 f100
Post by 64 f100 »
Thanks, I am tempted to just use high temp silicone sealer. Just afraid of damaging the heads. I thought of copper but with steel headers and aluminum heads I was concerned about metal reactions with each other. And yes copper gaskets are nice and expensive, but prices on all gaskets are high. Frankly, I bought the aluminum ones for half what I would have had to pay Jegs amd Summit, or any local parts house.
chris401
Post by chris401 »
64 f100 wrote:What would work best? I've ordered a set of aluminum gaskets that are layered, but have also noticed some stainless made in the same way in layers. Mostly concerned about damage to the heads. What experience have most of you had with this application?
Look at Remflex. There material is as as stated. Mine have been reused once. It looks like the same material I have seen in oil field equipment and near automotive catalytic converters.
LM14
Post by LM14 »
On my dirt late model engines, we never used header gaskets. Red silicone on the header flange, let it skim over and snug them down evenly. Run it to heat it once and let it thoroughly cool. Once cooled, snug the bolts again. If you try to tighten them hot, it will squeeze all the silicone out of the seal and you will have steel against aluminum. 1/4" bead all the way around the header ports works fine.
HotRodMatt
Post by HotRodMatt »
remflex the best and the only thing i or our shop uses.
64 f100
Post by 64 f100 »
Thank you all for the advice and knowledge. I will check into the remflex gaskets.
64 f100
Post by 64 f100 »
For those that suggested remflex gaskets, I have a question. I bought a set and these look good but I have one problem I need to ask about. These gaskets are about 3/8 inch thick that I received. Are yours that thick? What this does is only leaves about 3/8 inch of the bolt sticking thru on the head side. Since these are aluminum heads, I prefer the bolts stick thru farther. I may have to buy bowtie header bolts to fit right.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
HotRodMatt
some times we buy longer bolts for them if they were iron i would just snug them down.
1.0 inch header bolts will be good. they are supposed to squish a good amount, i think it 35 foot pounds? says on package.
good luck!
chris401
Post by chris401 »
They will crush.
bird55
Post by bird55 »
I use allen head setscrews with washers and nuts. Much better control on torque and protection of the head. Also use some type of antiiseize. I can buy them locally so I don't know where to suggest getting except possibly McMaster-Carr.
And in some cases this makes it easier to hang the headers with a few studs instead of trying to start bolts. :cussing:
