63 f100 cv ifs swap
Sliknik63
63 f100 cv ifs swap
Post by Sliknik63 »
just started 63 f100 long bed cv swap anyone have measurement for alignment pin location
RustNdust65
Re: 63 f100 cv ifs swap
Post by RustNdust65 »
Just measured mine. Granted I have a 65 it shouldn't make a difference. I measured 22.5 inches back from the centerline of the large radiator support holes. Give or take a 32nd. If that doesn't look right when you set the subframe under there i believe the wheel base for your truck is 122". Make a plum bob and some marks on the ground to get it as close as you can.
LM14
Post by LM14 »
63 frame is totally different than a 65 frame.
RustNdust65
I'm aware of this. Regardless, measuring the wheelbase is probably the best way to find the the placement he needs
