And as luck would have it, somehow I received TWO copies of this brochure. While at first I was ticked off 'cause I thought I'd wasted money on what I thought was a duplicate, I discovered that I actually had both the original brochure (printed 8/63) AND the Revised edition (printed 2/64)! I spent some time comparing the two and have put together this list (with graphics) to illustrate the seven revisions made in the second printing.
In the 2/64 revision:
Page 2:
Removed "..side-mounted tire carrier, Custom Cab, chrome hub caps.." from description.
Page 3:
Page 5:
- Edits the line "Insulation, 26 pounds of it..." to "Insulation, 38 pounds of it...".
- Added 'gray' to the list of available interior colors
Also on
Page 5:
Edits "Ford Motor Company warrants to its dealers, and its dealers, in turn, warrant to owners as follows:" to "Ford Dealers warrant to truck owners as follows:".
Page 6:
- The 3300-lb capacity rear axle entry was changed to delete the "3300" capacity.
- Navajo Beige was dropped from the standard available colors and Pagoda Green was added.
- Heavy-duty shock absorbers was added to the optional equipment list.
- In the 'Wheels' entry, the letter "K" was added.
