NEED HELP!!
slixty6
NEED HELP!!
Post by slixty6 »
I'm in the process of replacing the bearings and seals on my 66 swb f100. It has the 9 inch rear end, and from all the research I've done, I believe they are the big bearing old style type.
My question is, where is a good place to get these parts? Do parts stores carry them, or order online?
What information do I need to get the correct ones? I ask this because after googling this, all I can find is bearings by measurements.
Also, when I pulled the axles, the gear oil looked like mud. Will the center section be ok with just a good cleaning?
Thanks for any help. I do research a lot before bothering others, but when I can't find the answer, well.....
Michelle
Re: NEED HELP!!
Post by Michelle »
I bought a new set just a couple of years ago at the local mom and pop parts store here in my hometown. You shouldn't have any problem finding them.
Michelle
slixty6
Re: NEED HELP!!
Post by slixty6 »
I was wondering if my local parts places carried them. Thanks Michelle!!
LM14
Re: NEED HELP!!
Post by LM14 »
Give the center section a good cleaning and visually inspect all the gear teeth and bearings you can see as you slowly turn it over. Sometimes a good flush and new grease can buy a lot of miles. If the teeth show any pitting, I would replace everything.
Any parts store should be able to get the bearings and seals. Nothing special.
