I am installing a different engine.
What is the angle of the output shaft of the transmission?
My pinion angle is 6 degrees with no engine.
Thank you!
Engine angle
- Blackwaterforge
Engine angle
Hunter's 64
Re: Engine angle
ive always just leveled engine in truck by carb. mounting plate, tail shaft angle is what it is, drive shaft u joints should take care of diffrences ?
Danny
Danny
- FORDification
Re: Engine angle
Try looking over the Body Builders Layout Books...they might help. While they don't specifically give a measurement in degrees, they do specify how much lower the transmission output shaft centerline needs to be below the top of the frame.
http://www.fordification.info/tech/bodybuilder.htm
Keith
FORDification.info | FORDification.com | FORDification.net
Also own: '67 F100 2WD SWB - '68 F100 SWB 4WD choptop - '75 F250 Ranger XLT Supercab Camper Special
Re: Engine angle
Stock angle is 4.66 degrees...its on those frame dimension sheets, but hard to pick out.
- Blackwaterforge
Re: Engine angle
Thank youthird66go wrote:Stock angle is 4.66 degrees...its on those frame dimension sheets, but hard to pick out.
That is what I needed to know
