Can someone who has an assembled flareside step post a photo of theirs?
Here is mine. I have to do some fabricating....
It was full of bondo when I got it (hiding this giant rust hole).
I want to be able to fill this open area. Not sure how I'm going to yet.
Thanks.
'63 F100 Custom Cab 223inline 6, 3speed manual- mostly stock https://www.youtube.com/coastiereid
I don't have a read close up picture but I think you can see the polished stainless strip right above the running board on the bottom of the rear fender. I didn't have a rust problem but the rear fenders was off a mid 70's pick up and didn't go down far enough to mate up with the running board properly. I cut two pieces of stainless and rounded the other edge and made an extension, that solved the problem. You might try this approach to your problem. The extra bling set the truck off quite well.
Michelle
That's my Holy Grail Truck Michelle! 56 big window. I will have one!
Unless someone gets to it before I do I'll get a picture of my flareside step after work today. Kinda rusty I hope I don't have a bigger hole there than you do but I'll check.
That's what I ended up figuring out. I cut a notch in the newly installed bed side extensions. Pulled the step up closer. I still had to tinker with it. Had to fill the old hardware holes and drill new ones.
