Upper arch just cut but still in place.
New upper flat rail.
Frame holes filled.
View from inside of frame.
Lengthwise photo showing a more flat top rail, not completely flat, but rear cross member keeps the last small bump in place.
I'm going to second farmmotorsoorts opinion. I would box wide enough to get near one of the cross members and call it good. As long as the flanges are in good shape I think it will be strong enough.FarmMotorSports wrote:In my humble opinion, boxing the altered area should provide all the strength needed .
If you're planing on some serious abuse, you can use an L shape doubler on the outside of the frame, Between spring perches. It would be over kill for most street driven trucks.![]()
