Front axle swap?
64 f100
Front axle swap?
Post by 64 f100 »
My 66 4x4 is in need of better brakes on the front and I have been thinking about disc brake conversion, for which there is a kit fro roughly 750$ on Evilbay. However, I also need one seal replaced and who knows what else. Wondering if there is a later front end from a Bronco or truck with disc brakes that might bolt in. Any information out there on this swap?
Thanks,
Re: Front axle swap?
78-79 bronco or any 70s f100 4x4 with disc brakes are bolt in swaps
64 f100
Post by 64 f100 »
Thanks Ice, how about power steering conversion? My truck has the old main drag link with the spring and adjusting screw which with big tires tend to be a little sloppy. Any info on what I can replace the drag link with and still use the original box?
