first post: brake light diagnosis?
Re: first post: brake light diagnosis?
Glad you got it fixed!
1034 was replaced by the 1157, IIRC, it had to do with the industry switch to alternator systems. 1157 is a direct, supposedly more durable replacement.
Again, IIRC, the 1054 is a dual element bayonet type bulb, but does not have the offset lugs to correctly fit your sockets. I would assume it was simply forced in place, so likely not making good contact with correct terminals.
redstone65
Post by redstone65 »
Toyz wrote:...most likely flasher. My suggestion would be an electronic replacement...
Do you have a part number or a link to a suitable electronic flasher that would work? Just want to make sure I get the right thing. Thanks!
Dave
1965 F-100 Flareside (240 6-cyl)
3 speed. Former military truck.
redstone65
This works great. I think I still have a ground issue somewhere since the flasher was slowing down once the truck heated up. This flasher has it's own ground though, so it stays solid no matter what. Very nice.
Dave
