First drive after diesel conversion
Blackwaterforge
Post by Blackwaterforge »
Not quite Road ready but getting there
https://youtu.be/XPUVUUO0--g
ThinLizzy13
Re: First drive after diesel conversion
Post by ThinLizzy13 »
Awesome!
charliemccraney
Post by charliemccraney »
sweet
Lawrenceville, Ga
1961 F100 Unibody
FarmMotorSports
Post by FarmMotorSports »
Did you find an OD trans?
I'll let you know how the late 90's Dana 61 rear with 3.00 gears fits a slick.
It will definitely be wider than a stock slick Dana...
61 F250 Unibody
& 4WD
Blackwaterforge
Thanks guys!
I have a auxiliary transmission.
It is under/direct/over
chris401
Post by chris401 »
Blackwaterforge wrote:Thanks guys!
Is it a Spicer 5831-C, E or?
Blackwaterforge
[/quote]Is it a Spicer 5831-C, E or?[/quote]
It is a Watson , Brown/Lipe
Built by Spicer
It is smaller than a 5831
It weighs about 110lbs
chris401
Post by chris401 »
Built by Spicer
It weighs about 110lbs[/quote]Interested if the box makes road noise over the engine.
Blackwaterforge
Right now the gearbox dose not make noise over the engine.
Neither does the radio or cell phone.
I have the carpet and transmission cover off and a two foot exhaust pipe from the engine
chris401
Post by chris401 »
Blackwaterforge wrote:Right now the gearbox dose not make noise over the engine.
I like the 1.79 3rd gear and the 4.10 axle where they are in my truck now. A 3.54 gear and 5431-C or E would keep it there when in low. I have not been actively looking yet but know the gears I need. Did you find some literature on your Watson?
:shock: boy that thing can climb up hill well ! , good work ! :clap:
