Gonna install all three on the 250 this weekend,l heard that u-joints need to be installed in a specific relation to each other....anyone have some experience on this.....
U-Joint Question
U-Joint Question
Re: U-Joint Question
The u-joints have to be in line or what they call in the same phase. Replacing the u-joint won't change that but pulling the driveshaft apart at the splines and turning it before splipping it back together will. If you plan on separating the two pieces make sure the yokes/u-joints are lined up when you slip it back together or mark them before disassembly so you can reassemble the same way.
This isn't drive shafts ... but you will get the idea
https://m.youtube.com/watch?v=9unvQ-xf_XA
Neat video that mkes it simple to understand driveline angle
And phasing is important
https://m.youtube.com/watch?v=Idk3BVDVHq4
- FarmMotorSports
It is considered good practice to put u-joints in a position that will compress the Opening for the grease zerk when the vehicles moving forward... YMMV.
61 F250 Unibody
& 4WD
& 4WD
