Another easy fix....
Mr. Jones
Post by Mr. Jones »
Attempted to start the 250 one morning last week,turned the key and nothing happened.All the lights worked,lights wipers no problem.....hooked up a remote starter button on the solenoid....hit it and it fired up....so I replaced the solenoid.....same thing wouldn't start with key.... with remote yes.....today I picked up a new ignition switch to install......I had a thin wire inserted into that tiny hole for removing the tumbler,,wasn't sure about turning the key to left/right??? With the wire still in it I went to the right and the engine fired up........removed the wire and tried again,it started up,tried several more times and it always worked......
Seems weird just sticking a wire in it.And now it works
Re: Another easy fix....
I'd say it's getting pretty worn
Why did you replace the solenoid when it worked ? :oops:
Just good old fashioned stubbornness ? :mrgreen:
I would keep that remote starter switch nearby! Now there will be two dozen FB experts telling everyone how to fix a no-crank condition!
Mr. Jones
Post by Mr. Jones »
slick4x4 wrote:
Why did you replace the solenoid when it worked ? :mrgreen:
Since it didn't work with a key and did start with the remote my brain said it must be a bad solenoid,hadn't done the wire in hole at the time.....
OK, gotta ask; did you jumper the starter relay cables with the hand-held switch, or did you jump from battery cable to small "s" terminal?
BTW, you have got me sitting here playing with an old switch and cylinder; as Pat said, sounds like it's really worn!
Mr. Jones
Post by Mr. Jones »
Mr.Toyz,
Jumped the battery side of solenoid to the small one on the left side,fired up fine this am probably stopped and started twenty times before getting home and no noticeable play in the ignition..........
