1966 F250 Cummins gauges
- Blackwaterforge
Re: 1966 F250 Cummins gauges
That's looking very cool.
I like that anvil shifter knob. Undoubtedly you made that!
Bradshaw
Bradshaw
- Blackwaterforge
Thank you!9Fingers wrote:That's looking very cool.
I like that anvil shifter knob. Undoubtedly you forget that!
Bradshaw
Shifter knob was cast at Lawler foundry in Birmingham in 1933.
That is the year that Vulcan was entered in the Worlds fair.
I'm not familiar with this custom cab dash insert. What are the two small lamps between the speedometer cluster and each of the two side gauges? Are they turn signal indicators?
- Blackwaterforge
The dash is from a F800.
I added the lights.
One for oil pressure the other for alternator
I added the lights.
- FarmMotorSports
Which tach are you using, and how is it driven? The originals are cable driven, didn't like the idea of using a factory drive off the front of the cam...
61 F250 Unibody
& 4WD
& 4WD
- Blackwaterforge
Tach is electric from gas engine.FarmMotorSports wrote:Which tach are you using, and how is it driven? The originals are cable driven, didn't like the idea of using a factory drive off the front of the cam...
Driven by a Dakota digital drive.
Is there a better way to drive it?
- FarmMotorSports
I don't think there is a better way.... for an electronic tach.
My dash came with a mechanical tach, that I hope to convert to electric.
There is a mechanical tach drive kit made by cummins.
It takes the place of the timing cover plug/ oil fill. It consists of a tang drive that attaches to the cam gear. A threaded cable connector that fills the cover plug and a right angle drive. $$$ in cummins parts...
I'm using a alternator, electronic pulse driven tach to convert the old gauge face and case. If I ever actually do that project. About a $30 investment...
61 F250 Unibody
& 4WD
& 4WD
- Blackwaterforge
Tach is right at idle.
Should I adjust Dakota digital box til it is right at 2000 rpms and not worry about idle
- FarmMotorSports
Actually I would want it accurate at 1800 rpm give or take, it is where a 6BT motor makes peak torque and I believe 1700 is where yours peaks.
This is usually the best rpm for pulling power and cruseing economy. I'm not sure where you motor hits the governor, but it has been said that a cummins can run against the governor all day everyday without issues.
So Accuracy at minimum and maximum would be the least important to me.
61 F250 Unibody
& 4WD
& 4WD
- Blackwaterforge
Thank you
Well put!FarmMotorSports wrote:Actually I would want it accurate at 1800 rpm give or take, it is where a 6BT motor makes peak torque and I believe 1700 is where yours peaks.
