Bosch Tachometer / Painless wiring
Jerry D
Post by Jerry D »
I'll post this and see if anyone replies before I call the Painless wiring help line...
I bought a Bosch tachometer, and it's wanting me to run power to it that's only hot when the key is in the run position, and not OFF or Accessories key position. I'm trying to figure a good source wire to tap into. Ideas?
redstone65
Re: Bosch Tachometer / Painless wiring
Post by redstone65 »
The ignition wire should give you that right? The one that comes from the key and Y's into the distributor and the starter solenoid.
Dave
1965 F-100 Flareside (240 6-cyl)
3 speed. Former military truck.
Jerry D
Post by Jerry D »
Thanks for the reply. That's kinda what I was thinking. Called Painless anyway, and they said picking up the feed for the gages would work better. At the end of the day, I need to pick up a power feed for the tach light, so I can just pair/wire tie the two together, since they're coming from the same proximity.
