sheet metal thickness
I don't know if this is anything anyone can use but thought I would post it. I still have some metal work to do and started checking metal thickness and this is what I found on my '66.
front fenders - .046" =18 gauge
front inner fenders - .046" =18 gauge
hood = .035" = 20-21 gauge
doors = .042" = 19 gauge
rear fenders (flareside) = .048-.052" = 18 gauge
roof skin = .037" = 20 gauge
jamesdfo
Re: sheet metal thickness
Post by jamesdfo »
Grump: That's interesting, may I ask how you measured, and where on each panel?
James
I used a Starritt micrometer and had to measure on the edges. So on the rear fenders the top flange measured .052 and the bottom where it rolls under was .048. I tried to measure where there hadn't been stretching. oh yeah, I forgot the bed side and tailgate which were both at - .066" = 16 gauge. I'm sure there are exceptions to the rule on what I found since you all know quality control was not all that great back then. Don't know if this is of any use to anyone but here it is.
theastronaut
Post by theastronaut »
Metal stretches and thins out when its stamped into shape, so the thickness will be different all over the same panel depending on where you measure. You can make metal thicker by shrinking too.
I totally understand that, having worked for 46 years in a manufacturing plant. I took these readings on the edges where there shouldn't be much stretching or shrinking. When possible I took multiple measurments at different locations. I only posted this for general information so that someone isn't patching the floor with 23 gauge or the other way around. I just posted this for general information, it might be of help to someone.
It's a good reference
What little metal patching I do
I usally patch with something a bit lighter that original
Just because it's a bit easier to "form to fit"
oldsmiley
Post by oldsmiley »
And most anything that is a structural support is made of 14 ga. Like your rocker panels, front cab mounts, the front door pillars where your door hinges are, and the center cross brace that's under the cab, and runs from one door to the other door.
