Frames ?
jwh f-100
Frames ?
Post by jwh f-100 »
I am going to look at a 1986 4x4 F250 for my dump truck project. I was told at one time that the 250 and 350 frame are the same and the differences are only with the axles and/or the suspension. Can anyone verify if this is a fact????? OR is it the other way F250 and F150 frames are the same????
If this is true and I can trust that the frame will hold up I will try to locate a F350 rear as a donor for the springs, the rims, and the long studs to install the dual wheels. Yeah it sounds like alot of work but the price is right.
Also not sure what route I will take, a pto driven or a electric pump, but do these vintage auto trannys have a pto access?
Thanks! Jason
FORDBOYpete
Post by FORDBOYpete »
I am not sure of the frames after 1980, but from 1965 thru 1979 there is a difference between F-250 & F-350 that is determined by Max GVW.
The light duty F-250s up to 6900# GVW are the same for all intents & purposes as an F-150 of the same year, except have 8 lug wheel patttern and slightly heavier springs/ shocks.
HD F-250 & F-350's use a thicker steel like 1/4" as opposed to 3/16ths, & heavier springs, brakes etc as they are heavier duty. Also special duty, like Camper or Trailer special F-250 usually are the same as the F-350, atleast in the 73-79 version.
Having said all this above, when you get into dually frames, they are narrower in the C/A to accomodate the inner wheel of the dual wheel set up. Adding a dually rear end to a non dually chassis causes problems with rear wheel clearances to frame & wheel wells of the bed alike.
Now if you can find a '79, F-150 Trailer Special, it has a heavy frame, & huge front discs & rear drums, but uses 5 on 5.5 lug pattern of a standard F-100 or F-150's. It is a single rear wheel configurartion however.
Personally I have little regard for 80 & later F-Series trucks as they are/ were lighter and a reduction of the quality & durability FoMoCo was known for prior to 1980. Just my opinion :2cents: on FoMoCo F series frames.
Change is the Only Constant
FORDBOYpete
I ought to add here, generally speaking, the Cab & Chassis version like a "box" truck is built on or the Stake Body (aka OEM Flatbed) F-250 & 350 were built on are the dually based frames.
The trucks that had single rear wheels & came with a standard pick up bed/ box as opposed to Dually rears I mention above, are the ones with the wider rear frame area in the 73-79 versions. If a dually rear is installed on one of these that's where clearance problems occur. :hm:
It is easier to install a Dually rear on a 65-72 as they are -3" narrower than a 73-79. secret.gif
jwh f-100
Post by jwh f-100 »
Thanks FBP!
A buddy at work has a mid eighties F350 . I'll ask him to measure his frame for me for comparison. If this basis holds true up through the eighties I may need to rethink the dual wheel setup. When I was a kid and my faimly were still farming my father had two different single wheel chebby dump trucks and we never had any issues. If I am careful with my load capacities and install heavy ply tires I bet i would be fine with the single wheel set-up
Personally I have little regard for 80 & later F-Series trucks as they are/ were lighter and a reduction of the quality & durability FoMoCo was known for prior to 1980. Just my opinion on FoMoCo F series frames.
Yeah I agree. But the price and the truck itself is my best bet yet. I am going to look at a '79 2wd F350 cab & chassis. It is all set with no box, dents are my favorite but it has a "oil burning" 351m and engine swaps or repairs don't fit the budget........ Plus did I mention its a 351M :barf: :D :D
FORDBOYpete wrote:I am not sure of the frames after 1980, but from 1965 thru 1979 there is a difference between F-250 & F-350 that is determined by Max GVW.
1967 f350s were a big change from the 61-66.
they got the twin i beam front end and the frame shape was changed from the flat style to the f100/250 style raised over the rear axle. frame steel thickness is greater on the f350 than the 100/250.
36truck
Post by 36truck »
F350 dually has 34" frame spread single tire is wider frame.
Tom Williams
