bed mounting
ghostflamed66
bed mounting
Sorry guys but I have the a bad case of CRS. Cant Remember S***
I did a source with no results.
I got my 65 painted and cleared and want to mount box back on frame.
The truck has been apart for a couple of years and i dont remember what was between the box and rails.
I am thinking it was wood but dont know for sure, or what the thickness was.
Thanks for the help,
Wes
Wes
64 4x4 with tilt front end
65 f100
66 f100
66 ranger
66 fairlane 500
65 f100
66 f100
66 ranger
66 fairlane 500
ghostflamed66
Wes, i dont remember there being wood on the 64-66 styleside beds but there were on the uni, slabside and stepside.i will have to look and see. i had to change a couple on my 4x4 because the bed came from a 2wd with arched frame and the f250 4x4 has a flat frame.i made the new ones from pressure treated wood.
- Alan Mclennan
Wes,how`s it going,Lenore has got 2"x2"x1/2" reinforced rubber at each bolt position.Don`t know if thats wrong but works just fine
Alan,
Alan,
fmartin_gila
Wes, my Uni "had" (have made some adjustments after fixing the floors & mounts & replacing the front clip) from the firewall back in this order, standard cab mount donuts, then 2"x 2" x 1/2" reinforced rubber, from there back it has the wood blocks with the 2x2 rubber underneath them. My 66 short's bed was bolted right to the frame. The 64 lwb had the wood blocks only. You may have to experiment till your windline matches up, this could explain the differences.
I have taken three '66 F-100's apart and all three had redeck repairs. I remember rubber welting on one, which was probably factory. Metal to metal will squeak and wear, creating rust spots. The others had either wood or scrap metal shims, no rubber.
I used the big square threaded washers (Home Desperate or Lowes) that are used for hanging electical conduit for spacers when I put the bed back on my longbed. One or two will add about 3/4" of height where needed to line things up. Then cut a washer or two out of a plastic food container lid to keep the metal apart.
Trouble with slicks is, most of the time they look sway back even when the frame ain't bent:-)
Doug
Doug
My 64 short styleside had both the blocks of wood and the fabric that Bork mentioned. You can still get those from http://www.horkeyswoodandparts.com/IntroPage.htm
I didn't use the wood, just the fabric pieces.
Doug
Riverside, CA
Riverside, CA
61stepside
