7.3....Help.....
jwh f-100
7.3....Help.....
Post by jwh f-100 »
For my possible dump truck project I am looking at a 1989 F350 with a 7.3 liter (non turbo). What can you all tell me about the 7.3 . Are they bullet proof??? Super expensive to fix???? It has a ton of miles on it. It was a U-haul truck. Does anyone know if U-haul has a good maintenance program??? I am not sure but I am thinking it has had the engine changed at one time. The engine is painted orange and there is a decal on the valve cover that says
"U-Haul warranty" ( or something like that).
All input will be greatly appreciated!!! I am quite interested in this thing. All of the other trucks, in my budjet range, I look at are pretty rough to say the least. This may have a ton of miles but the frame and cab are very clean. If the 7.3 "puked" and I needed to put some money into it I would still have a good truck rather than getting a typical northeast rust bucket, need to dump money into just to still have a typical northeast rust bucket that may only last me a couple years.
Thanks!! Jason
64fordf100292v8
Post by 64fordf100292v8 »
Try to test drive it and see how it runs. I work at UPS and we have a bunch of 7.3's and there tough. See how it starts without the glow plugs, it should start fairly quickly indicating decent compression. Drive it and warm it up good, should be no blue/white smoke out the exhaust once its warm, little black is ok but only under acceleration. Look at the injection pump at the front of the engine right ahead of the air cleaner, If its leaking fuel all over it probably needs a rebuild and that gets expensive.
Hope this helps. :)
jwh f-100
Post by jwh f-100 »
Thanks!!
Definately helps. I have worked on some 444Es but kinda missed the boat. Soon after my employer became a IH dealer I got a supervisor position so most of my experience is working on 5.9 cummins engines. Sure do miss turning wrenches every day.
Jason
shawns fords
Post by shawns fords »
those were the best in my opninon, none of the modern tech crap on them like the newer 7.3ls = low maintenance and inexpensive repairs that can be done in your own driveway/garage. you can also upgrade to a banks turbo for highway useage if needed. a True diesel = glow plugs fuel filter/water seperator. and a relay. might not run 100 to 100 mph but it will still tow just as much as that 52k superduty will as much :D
adrianspeeder
Post by adrianspeeder »
7.3L IDI Basic bulletproof diesel motor. All the info you could ever need is over in the IDI section of www.oilburners.net
Adrianspeeder
