tractor question
willy3486
tractor question
Post by willy3486 »
Here a question for folks that know about tractors. I have a international tractor from the early 60s. around the valve stem in the back it is leaking. The way I understand it they put water in the tires for more balance. Well the water is seaping out around the valve stem and there is metal bubling up around the stem. It has rusted and caused the metal to flake up . My question is can this be repaired? Can they put a air valve stem that has a bigger base or can they weld up this hole and redrill a second one? I really don't want to find another rim and wouldn't know where to get one. Any suggestions?
Ford4jack
Post by Ford4jack »
You might want to remove the tire and see if the rust showing is just the tip of the iceberg Willy.
Remember some folks use a alcohol based antifreeze fluid in tractor tires.
If your rim is un repairable there's a few tractor bone yards around the area.
You should be able to find them advertised in the trader mags.
pipedobber
Post by pipedobber »
Depending on how bad it is, I have fixed rims before. Depending where the hole is in the rim, close to a lip or on the flat, it isn't too difficult of a job. The main thing most people look at is cosmetic. I usually cut me a patch and drill a hole for the valve stem and weld it on the inside of the rim. Just make sure when you are done you dress it up really well so all welding spatter and slag don't hurt the new tube.
blackagatha
Post by blackagatha »
WATER!?! that sounds like a bad idea... for the condition you're coming up against.
Wait, it has innertubes, right? how the hell could the water be rotting out the rim?
Ford4jack
Post by Ford4jack »
Some are tubeless some have tubes.
I never liked the idea of fluid in the tires myself.
Figure its just putting an unnecessary load on the drive train.
MrEvil
Post by MrEvil »
You may want to go ahead and pull the wheel. Alot of old tractors had Calcium put in the tires before they ever got water put in there. The Moline G1000 my dad bought had rims so bad that they were beyond repair.
Vehicles:
2000 F250 Superduty Crew cab
1998 Ford Crown Victoria Police Interceptor(work beater)
1961 F100 Uni (my baby)
1966 Thunderbird: someday.
jwh f-100
Post by jwh f-100 »
Willy,
Normally it is calcium in the tires and it is there for extra weight for traction. Where you see the paint bubbling the calcium is rusting your rim, just like the salt on the roads rusting out a vehicle in the great north-east. If it is calcium you may want to check in your area for someone who will repair it. They should have the equipment to remove the calcium for repairs.
Jason
blackagatha
Calcium??? how strange... I learn something on here almost every day...
GLindley
Post by GLindley »
Yeah, BA, I have heard of using anti-freeze in tractor tires for weight and traction, but not calcium. I did a quick search and found this on the fly..
http://www.wardchem.com/tire-weighting.htm
Gene
1961 Intregal cab SWB 223 (getting 302 & TIB)
1969 LWB 302 automatic (Donor for the '61)
2000 F150 XLT SWB (Daily Driver)
36truck
Post by 36truck »
Calcium chloride has been used for years as weight in tractor tires. If the tire is filled so that no air gets to the metal rim it won't rust.
Tom Williams
blackagatha
SO the tire is totally "inflated" with this Liquid Calcium stuff???? Never heard of such a thing...
I have seen LOTS of tractors with big cast Iron weights bolted to the rims, but never knew of any (that I was aware of) with this stuff in them...
How could they fill it past the level of the top of the rim? it would just be a huge void... kinda like holding a pot upside down in the bathtub, it will keep all its air in the top.... ANd if you have to displace air with this goo, that would just make it all complicated, wouldn't it?
36truck
Post by 36truck »
The tire changer people have special pumps to put it in and take it out.
Tom Williams
blackagatha
weird man....
Rustbucket
Post by Rustbucket »
I pulled the wheels off the 8n . Not realizing that they are completey filled to the top of the tire. I was useing some mussels I forgot I had, trying to hold them up. They don`t look like they have tubes. I allways thought they had tubes, keeping the calcium away from the steel rim?
1965 F-100 Shortbed 351W.
1969 F-250 Camper Special
1984 Mustang Convertible
1949 8N Tractor
jwh f-100
Post by jwh f-100 »
rustbucket,
Some do some do not.
Dang you guys!!!! I grew up on a farm and always wanted a tractor but Dang you guys (!!!!) are a bad influence. Now I want a tractor!
I like this one
http://cgi.ebay.com/ebaymotors/1953-For ... dZViewItem
36truck
Post by 36truck »
jwh f-100 that is one wild tractor a flat head V8 in it. Better not use all 110hp
it has parts will be breaking. :D Looks real clean tho. 8) :D
Tom Williams
Rustbucket
I heard about those conversions with the flathead V8. ( www.staufferv8.com). They are neat. It will be interesting to see what that tractor sells for. jwh f-100, New Jersey is not that far away! Sure is a nice tractor! Dale
1949 8N Tractor
blackagatha
nice... haha wheely bars...
I bet that thing would whoop at the antique tractor pulls that they have at the county fairs... Well, we have them in Tucson anyway.... sounds like fun.
