Slick broke down in Va.
Wow, I am out, you covered all of my ideas. Multiple distributors would eliminate the ground problem unless they all had a bad ground and that is unlikely. The duraspark box does not have an internal ground, it is grounded inside the distributor by the retaining screw for the pickup module. Follow the black wire out past the connector and in your main harness cut the wire and splice in a ground. I don't like to modify the pickup or the module wires as that makes replacement a problem in emergencies. I hate to say this but pull the valve covers and watch for rockers not moving. Wiped lobes will often run fine but sluggish. The module should not be making a difference but you can never tell. Hawkrod
- 6166 Junkyard Dog
Banjo unloaded truck, started right up on the back and backed it off, let it warm up but still getting all choked
Kathy
Now Cooper will try his best
unibodyboy
Banjo,
I know it's along shot but what year is yoru truck? I ask becasue I had a very similar problem. On the earlier slicks, there is a difference in coils. One was internally resisted and the other wasn't. There wire coming from the Ignition switch that has an internal resistor stock. It took me a long time to figure it out. The only reason I suggest that, is that it would run, but only for a bit and it had the same types of symptoms you are having. You said something about a Y block in your posts, and that would lead me to beleive you may have an internally resisted wire in yoru stock harness. Something to think about.
Greater love has no man than this, that a man lay down his life for his friends. John 15.13
Hawkrod wrote:I hate to say this but pull the valve covers and watch for rockers not moving. Wiped lobes will often run fine but sluggish.
Good luck with the problem Banjo, hopefully the rest of your move goes well.
Merry Christmas to you & yours.
When you get it to stumbling, pour a soda cap of fuel into the carb, if the RMPs elevate, check your fuel pump pressure and fuel pick up.
You said it runs fine at idle and up to 1000 rpms, if your peressure is low and is restricted, you could be picking up some rust/debris from the tank.
Fastest way to check fuel line is to remove line at pump, install a temp line and use a coffe can or fuel jug.
I hate Message Boards.
- needmoretime
Banjo,
I hope it works out for you! It just happened at the wrong time with all that is going on.
On the sunny side of things you have more chance down there to work on it than up here with winter time and all.
Let us know how you make out and what you find. Thanks to Tom for helping out!!!
Everyone have a merry Christmas!
Wayne
Wayne
truckerdaddy66
- Ranchero50
Still, if you go back to the original complaint, three boxes three different problems points to the boxes themselves. It's been ages since I played with one, but the only stumbling block was whether the red or white wire got 12vdc running or starting. Seems like I usually got it backward and the box would get hot. I remember reading that the box fires hotter on the start circuit vs the run. I also remember reading from way back when that common complaint was the box overheating on the mustang II's because guys wold put an open element air cleaner on the car and the airflow inside the engine compartment would change letting them get hot.
Jamie
Jamie
66camperspecial
From what I understand of these systems, grounding of the box is critical. It must be grounded well. I cannot see how running backwards could be caused by fuel problems, but never say never. Cam lobe should not cause the problems as described either. Just making guesses here, but broken cam, or something along those lines? Loose cam gear? Wet wiring causing short? All boxes ruined by ppor ground? Shorting rotor? Since changing boxes changes running, check for bad wiring to and from box?
- needmoretime
- Alan Mclennan
- banjopicker66
Sorry to keep you guys waiting! I haven't done anything yet, my poor Slick is still in NC with Flashback Tom.
I really do not have a place yet to keep it. I am considering driving my Super Duty up there and tow it back myself, but my F-250 SD is in the shop. HPOP problems.
I WILL keep you posted, as to when she gets home, and as to the solution.
Guys, you are all great friends, and I am grateful for each of you that have replied.
- needmoretime
- 6166 Junkyard Dog
Wayne you ought see the 65 sitting here from Calif,, a untouched virgin truck that has not been cut into,, its beige close enough to white
I think anyway I cranked Banjo's truck a few times runs good around here as long as I don't go over 1000 Rpm's,,
On the 6.0 diesel's have you ever heard that if you are low on fuel on the gauge or gauge shows empty even though you have plenty of fuel that the computer starts shutting down the motor or even can wipe out the injectors
Thats what is a problem starting to develope on my truck, buy lucky enough they caught it at Ford before it got serious
Kathy
