TRANNY INFO
63lokinup
TRANNY INFO
Post by 63lokinup »
MORNING MEN, GOT TO LOOKIN' AT THE WIRING YESTERDAY , TOOK THE SEAT OUT AND THEN THE MAT, INSULATION, THAT FLOOR PAN THAT WAS A BEAR. THE QUESTION IS ...N-2 ? ON THE SIDE OF THE TRANNY, GOT TO GET THAT CLUTCH TODAY, THE LINKAGE RODS ARE SO USED. ANY INFO WOULD BE HELPFUL.
MARK
Re: TRANNY INFO
63lokinup wrote:MORNING MEN, GOT TO LOOKIN' AT THE WIRING YESTERDAY , TOOK THE SEAT OUT AND THEN THE MAT, INSULATION, THAT FLOOR PAN THAT WAS A BEAR. THE QUESTION IS ...N-2 ? ON THE SIDE OF THE TRANNY, GOT TO GET THAT CLUTCH TODAY, THE LINKAGE RODS ARE SO USED. ANY INFO WOULD BE HELPFUL.
MARK
if you have linkage rods, then its the ford 3 speed trans. and there should be no problem getting a replacement clutch set.
Keith has excellent diagrams on all the trannys and linkages
http://www.fordification.com/schematics-g.htm
63lokinup
Post by 63lokinup »
LOOKED AT THAT SIGHT AND THAT TRANNY I HAVE IS A FOUR SPEED I GUESS THEY CALL THAT OVERDRIVE THEN....I GOT TO CLEAN THAT UP...IT SOUNDS OK, GOING TO REPLACE THE CLUTCH AND EVERYTHING.\\MARK
oldtrucks
Post by oldtrucks »
63lokinup
Same trans only with an overdrive unit added. Post a pix and then we can tell for sure. As far as I can remember 3 speed and the granny four speeds F250 and down pretty much use the same clutch packs. Only difference being the clutch diameter. Input shafts are the same diameter and spline count.
Mike Kincheloe
Mikes Old Trucks
I restore old trucks and cars
1962 UNI Short Box, Stock Y block, 4 speed Image
1972 F 250 4X4 429 4 speed Dana 70 rear
1977 F 350 Camper Special, Ranger, Super Cab
1950 F7 Cab and Chassis
1976 F150 4 Speed 4 X 4
1996 Taurus
