lucky day today
Ford4jack
lucky day today
Post by Ford4jack »
Well my old mower has been knocking for about 3 years (loose counterbalancer). Got tired of mowing slower each year and was able to pick up a 16 hp twin engine for it. Rebuilt the trans and got the engine mounted and was able to test run it today. Looks like I will be mowing in high gear now. Sounds good also.
Picked up a 45 ft box trailer today Hooray more storage for this pack rat.
Had a chain break on my chainsaw today I have never had that happen before but have heard some bad story's about that happening. Mine just strayed in the log.
All in all a good day here.
[albumimg]3750[/albumimg]
36truck
Post by 36truck »
That mower is going to scream with that much power. :shock: :D :D :D
Tom Williams
Ford4jack
Post by Ford4jack »
Hopefully the front end and trans will hold up our yard is a bit on the rough side.
When I first got it running it had straight pipes reminded me of the old flathead dune buggy's of my youth.
the wife was not impressed but the dog loved it.
Decided to keep the piece around here and put mufflers on it. No use in catching the yard on fire also but it did sound great.
The burnouts will eventually make mowing unnecessary. :shock:
robert porterfield
Post by robert porterfield »
that sould "go" good enough to possibly do a little "drifting" :shock: !!!!!!
lifes hard wear helmet!
did the chain break or just come off the bar?
have had both happen before, one time i got hit just below the kneecap. barely broke skin but it was my own fault , should not have been cutting dinky wood with my 28" bar and chain. chain was just a little loose and a limb snagged the chain enough to pull it off the bar.
Ford4jack
Post by Ford4jack »
It broke at a link pin looks like one side of the pin broke then the link plate on the other side snapped at the hole.
Kinda strange it was a Oregon chain with only 15-20 hrs on it guess I should see if it was where it was linked at. I had the guy at the local baileys store made it from bulk chain and he might have pined it a bit tight or something.
Yea long bars will get ya if they get a chance for sure. Had a friend get cut topping with one like you say the chain gets just a little loose on those and watch out.
Went and looked at the trailer I bought the other day. I had seen it before I cut the keyway into a bank behind his house where he set it up at. Hell I stole that trailer its a 45' Fruehauf clean on the outside and dry on the inside has the sliding spring tandem axles with good looking brakes and drums and a straight set of stands that work correctly. Only has 6 tires on it he used the other 2 to be able to tow a school bus in for scrap.
Gave 400.00 bucks for it he needed the cash to keep his son out of jail. Figure I will through in some free backhoe work for him no need in robbing the guy because he was down on his luck.
Well I'm rambling on again nuts.gif when I do this it means I'm on the pain med's.
Had my new son in law over this weekend and he is getting into judo.His instructor told him splitting wood was a good bodybuilding exercise. He made the offer so I spent yesterday cutting some good splitting blocks for him.
I know better than to handle those big chunks with trashed out wrists and knees but I wanted to have plenty for him to split. Its not everyday you get an offer like that :D
blackagatha
Post by blackagatha »
mmm snapper...
that thing should haul. Betcha it would whoop at the mower races... Put the straightpipes back on and make some flamethrowers for the pipes.... that's be great.
On other ideas brought into this thread.... All that about chainsaws throwin chains is terrifying.... holy shit. Well, I guess they're notoriously hazardous even under the best circumstances...
Ford4jack
Post by Ford4jack »
guess flamethrowers would work well.
Just burning the yard off instead of mowing it might be an improvement to our yard.
Checked that chain today it did break where it was linked guess I need to stay away from bulk cut chains
The scariest thing I ever did with a chain saw was to cut a log off a huge ash tree that had blown over.
I had topped it and went to cut the log off the stump when I did this the stump flipped back down and it grabbed the saw out of my hands and thru it about 30 feet into the woods.
That sure was a stupid thing to do the stump probably weighed 3 tons with all the dirt it had on it.
Had a pair of young beagles with me and it flashed thru my mind that they might have been under that stump.
The dogs were fine they were off chasing a rabbit It ruined the bar on the saw so all & all it ended up being a cheap lesson.
blackagatha
holy shit!
At least it threw it away from you, not a kickback situation.
The whole bulk chain thing sounds scary. Already scary tools, then let the kid at the hardware store go makin em hokey.... eekgads.
My dad was choppin on a 18" olive tree log that broke out of the tree over at my grandparents' some years back; couldn't get Gpa's crappy MontgomeryWard's saw runnin, so he was using his big bow saw, had the tree propped up on a chunk of gas pipe so it wouldn't hurt the tree any worse, found that the ONLY position he could cut it from was directly underneath. He was counting on his "Cat Like Reflexes" which actually panned out that day... He jumped out of the way just as it came smashing down on top of him...
OH and my neighbor cut 2 fingers off his left hand with a little electric saw... Idiot was cutting up some brushy crap and he was tryin to clear some of it out of the way (without turning the saw off) when the damn thing snagged on something- because he wasn't paying it any attention, and jumped up and bit his fingers off.
He was scrambling around in the dirt, looking for them, realized that they didnt come clean off, they were folded into the palm of his hand. He ran inside and told his wife and 2 girls what he did. 3 drivers, 3 cars, no keys. He started walking for the hospital (1/2 block away), got all but in the driveway before somebody came and got him.
Got some "little kid" doogie-houser type guy to fix him up. Crazy good surgeon. Hes got all the feeling and everything. It was important because he was a cop and had to qualify shooting with both hands....
We've been halfway terrified of chainsaws ever since...
FORDBOYpete
Post by FORDBOYpete »
Jack,
On your twin 16 Briggs, I have 1 in a Deere Rider vintage 1985. The one I have left is a Hydrostatic Drive. I can move a 16" flatbed trailer around the yard, plus pull lighter, disabled, vehicles with it, like a fox body '85 T-Bird for instance. We also use it to pull smaller trailers while harvesting Pine Straw to sell as mulch.
Thing you gotta watch is engine oil in those Briggs, Twin, "Flat 16s". Use the right oil. Keep it clean & fresh. Oiling System is not a full pressure system. It's dipper & splash type. Engine tilt & hill angles become critical when mowing. I been using 40W High Detergent & change it every 100-125 hrs. Still Do in fact.
Another thing I discovered is OEM, common Muffler or a common exhaust chamber design inhibits reversion in the twin 16's. You have 1 carb & a common intake manifold and the use of a common or equalizing chamber in the exhaust system balances alternate cylinder flow freeing it up at low & Midrange RPM. Nah it doesn't sound as "Nasty" with the common chamber, but it runs better, seems stronger, and seems to last longer than with two, single side, exhaust stacks. Another thing I'd tell you is keep your engine shrouds debris free so you get best air circulation you can. Engine Oil cools as well as lubricates Flat Twin 16's.
I had several J Deere 116 riders, with a 38" cut we used commercially from 85 thru 95 or so. The 1 I have left is 23 years old & still going great. Most of the others suffered catastrophic failures or either got sold off B4 they gave up. Helpers didn't help them survive either. Didn't watch engine Tilt & Angle. They were remiss about keeping up with engine oil too, altho they said not. :hm:
FWIW, next county west of here they "race" Riding Mowers, Hydro's aren't the ticket there, hard gears are. but well built & maintained 16 Twins do well & often take home the $$$$. . . . Not my sport however :roll:
I just thought you'd like to know this stuff.
Also somewhere I have the OEM Service & Repair Shop Manual on Briggs Twin 16, altho' :hm: I'm not sure where it is right now shrug.gif . . . .
Change is the Only Constant
Ford4jack
Post by Ford4jack »
That's some good info Pete thanks. :thumright:
Unfortunately our yard is basically all hillside so I guess I need to ask if there's a best side to tilt the engine to.
I have also wondered if you check the oil on these by just dipping the stick or if I need to screw it down to get the proper check on the oil level.
My first thought on a muffler was to weld the down tubes into a section of exhaust tubing mounted horizontally then weld the mufflers on the ends but after removing the tubes I saw the ports were threaded so I went for the quick and easy route. Sounds like I had better go with my first thought on it.
Guys this mower will still have the same ground speed as always that's kind of set in stone on a snapper
What my thoughts are is I should be able to pull a higher gear while mowing after I "port" the discharge chute area
I have seen a hydrostatic mower haul ass. When I worked down at the Deere dealership the mower mechanic
was working on a 900 series commercial mower and ether got the swash plate installed wrong or had the linkage set wrong but the thing would fly. He kept everyone entertained for a couple of days on that one. He would cuss and wrench on for a while test run it and come back and try something else.
That thing would hit al least 25 mph in the space of 4 bays and the engine would just be starting to get wound up. There's no telling how fast it would have gone wide open.
Pete are you anywhere near West palm Beach. My youngest girl and her boyfriend got in a hit and run accident there in January. Some drunk driver blew a red light and clipped the front end of her car. Her boyfriend hopped out and saw no leaks so they took off after the guy. They caught up with him she said he was only able to go about 50 because his wheel on the Hyundai was wobbling so badly. Anyway the got his licence number but before they could call it in 5 patrol cars showed up and pulled the guy over. Apparently someone had called in about the guy. Sounds like the law is on the ball down there.
FORDBOYpete
Hi Jack,
I screw dip in to check the oil. Get it too full & ya' gotta an anti mosquito fogger going on. Seeing as pistons fire
horizontally I doubt it makes much difference which side is downhill, ya' know? It really prefers level I believe. 8)
Yeah, on the Muffler into a common chamber. Your 1st scheme was right.
Not very close to West Palm, Martin Co. FL. I'm just outside of Daytona, about 2 hrs north of W.Palm with the right traffic.
I-95 can be a "be-atch" sometimes. I've spent hours just sitting 10 miles from a "get off" for a wreck on road upahead. :shock:
As for law enforcement here abouts, YES! They do their job rather well I'd say. :lol:
Wish I could say same for courts tho'. When "Legal Seagulls" get together it's a feeding frenzy. Another name for
seagulls 'round here is "Dump Ducks" because they seem to congregate at landfills where perform the same sort of
feeding frenzy as court system does, only in court innocent victims & Gen Public get "eaten" instead of "Perps"
& other garbage, if ya catch my drift. :roll:
Few times lately they chased the worst criminal types with hot lead. Not much argument in court that way.
Ya know what I mean? :wink:
CIAO,
