64 ford 4x4
rkibbon
64 ford 4x4
Post by rkibbon »
What do I need to install a 352 from 66 2x4 into the 64 4x4, bell housing same or different, can the mount from the 66 work in the 64?? Any clearance problems??? New to this, but I had a 64 w/352 yrs ago, but wrecked.
robert porterfield
Post by robert porterfield »
you will need an fe bell housing w/the motor mounts on it also the cast iron fe timing cover for use w/the front motor mount...... what is currently in the 64? 292?
lifes hard wear helmet!
backwards of installing the 292 in a 66 f250 4x4 like i did.
the 292 is 2" longer than the fe, i had to move the front crosssmember forward, i would think you must move it back toward the cab or make a plate.
Brent
Post by Brent »
I used frame mounts off of a 76 f-250 4x4 for my 63 4x4
I had to box in the frame about a foot on each side and bolt the frame brackets to the frame.
I was going to try the bell housing and timing cover mount but I couldn't find the timing cover.
I think there is a cross member available for this swap don't know if it will work on the 4x4.
63 F-100 4x4
74 Gran Torino
96 Ranger STX 4x4
6Slick5
Post by 6Slick5 »
Ron
Glad to see you made it on here! I have never messed with a 4X4 and prefer 6 cylinder engines myself.
Shot me an email sometime and maybe we can get together and discuss our trucks!
Marty
65 F-100
94 F-150 (Daily Driver)
2006 Vibe (Wife's Car)
65 Karmen Ghia (Son's Car)
Iron Horse Bicycle, trying to save some gas money!
