Frame and rear spring qustion
Robert
Post by Robert »
Ok i have a qustion what would happen if i boxed my frame and in the back take the spring hangers and move them to the inside of the frame what kind of ride would i have
insane1
Post by insane1 »
As long as you dont change the leaves themselves it dosent matter on which side of the frame they are mounted, it will ride the same.
Ford4jack
Post by Ford4jack »
Seems like you would get a bit more body roll doing that.
A sway bar might help guess it depends on what your setting the truck up to do.
greythorn3
Post by greythorn3 »
i dont know about that but using a longer spring will give you a better ride.
Ray
wheelordie.com my alaska offroad website
