460 Cores worth anything?
- ripsnorter
I've got about 7 1969 - 1971 Lincoln Mark IIIs that went through a flood years ago. They are all 460 engines, no smog etc on them, but all been flooded and filled with water and are toast.
Are they worth anything as cores?
I'm trying to figure out if I should spend the hour or two it would take on each car to get the motors out.
Any thoughts?
Any thoughts?
- ripsnorter
Forgot to mention that we're sending all but one of these cars down to the crusher. So if I dont pull the engines out theyre just going for scrap.
I dont want to screw around pulling them though if they dont even have any value as cores.
When I say core I mean of course a rebuildable block, heads etc. I've always been told that even when theyre rusted solid you can cut the pistons out and rebuild the blocks and heads. I guess I'm mainly wondering if its even worth doing though, if the early non-smog 460s are that valuable/cool.
- FORDMANLCRACKEL
You might want to ask the boys over at 460ford.com
Lonnie
Lonnie
- banjopicker66
I would save the following, if you have the time to pull them, and then sell them on E-bay, as the 460 is a popular conversion for trucks and cars:
C-6 transmissions with slip joint putput shaft, possibly driveshaft too (give the driveshaft away if you use "Buy It Now" sort of thing.)
Heads - especially C8 or D0 heads. Check the casting codes carefully, if any do not have the "V" in the casting number, they may be performance heads. (V is for Lincoln, but O is for cars - and if "O" could be CJ or even SCJ. Rare, but possible.)
Don't go to the trouble to kaeep any D2V heads - they are worthless. No quench area, and highly prone to detonation.
Brackets and pulleys - complete, for 460 conversions as well. Easy go for $100 a set on E-bay. Advertise with pictures of the proper setup, and they will go.
Finally, save the rear end punkin, maybe even the entire rear end, if you have a heat wrench. Ford 9 inch rears are getting harder to come by.
Hope this helps.
Hope this helps.
- FORDBOYpete
Banjo, AHh . . . Err a point of order my good sir. . . .
Lincoln C-6 of this circa are "Soft Shift", no engage clutching at high idle, and have the wierdest rear mount that fits nothing but these Mark III coupes. So saving them is not worth it for me. But if you want a slushy, soft shifting, power robbing A/T that requires you to get creative to install in a FoMoCo truck chassis well then. . . . .
They go with those silly rear "punkins" that look like a 9" FoMoCO but are 9.75 instead. . . . .
they are surely a no fit a 9" case with out work, and no gears available aftermarket.
Just thought you'd like to know this terrible news. . .
FBp
FBp
Change is the Only Constant
- banjopicker66
The carbs on the 69 460 aren't too bad.
- ripsnorter
It took me about 15-20 minutes of research before I found out that they were indeed NOT 9" rears.
As it is I pulled a complete engine, tranny and driveline (with some sort of harmonic ballancer on the driveline U-joints that I had never seen before) out of one of the '68s. Its very bad off but it was easy to get at since the front end was already off.
Theres one other that I'll pull for sure, the dipstick shows good oil and no water at all in it. I think that one missed the flood if I remember right.
Theres probably only 4 other motors (a few of them didnt have motors in them, I didnt notice that til now) and I doubt I'll even screw with pulling them as theyre all bad off.
Where would I look for the head numbers though?
- banjopicker66
shawns fords
wish I could have a few more around here, they arent so easy to find. I dont have 30 hours a week to spend in salvage yards looking either, the old stuff just aint there anymore. everything is modern junked wrecks. REMAN block core charges used to be 380 bucks for a FQR via ford. I paid 75 bucks for my 68 Thunderjet 429 that was locked up. Next one I ran across was at a swap meet and he wanted 700 bucks. with trans.
this is the good side
