Well I finally got my little 91 Mazda truck running great. Its had the carb upgraded to a webber, the vacuum advanced replaced, the fuel filter and gas tank replaced since it was rusty. The rust was my biggest problem causing it to slow down and have a hard time going uphill. Now it drives great and goes uphill fine. I do have a question on the truck since I am still getting use to it. It drives about like a Isuzu diesel box truck I use to drive some on a old job I had. It runs great but not made for a quick takeoff. Eventually it gets to speed, but from what I gather this is normal for these trucks and I am fine with that. Anyway when the truck is warmed up it runs about 1000 rpm in park. When I get it to 55 on a flat road I am at about 2000 rpm. At 65 on the interstate its about 2500 rpm. When I am going up a steep hill it goes to roughly 3000 sometimes. Its automatic and it doesn't have any trouble pulling or it does not slip. It basically runs fine. But I was wondering I have had times when I got it above 3000 and up to 3500 at times. I guess I am still skiddish about the rpm since I had trouble in the past. As far as speed goes if there is times I can get it to 3000-4000 rpm will this hurt the engine or transmission? I try to watch it and not get it over 3000 but I wonder if this is "babying " it too much. It could easily go to 3500 to about 4000 with no problems. I am thinking if it doesn't hurt I may try to go a little more rpm where it will go uphill a little faster. Most of the time I don't go over 3000 rpm and it can slow down to 45 mph. So whats a rpm not to go over? It has a automatic tranny and a 2 liter engine.
The only issue I have is that it has to warm up. The truck will shake just a little for a few minutes. You have to drive it before it warms up, I think the tranny has to warm up also, but it doesns't slip just takes it a mile or so before I can get it to 55-60. SO I am I babying it too much?
Engine rpm non slick question
- Johnny Canuck
blackagatha
the little jap engines will rev like all hell and last for 400,000 miles. floor it and hear it scream. Whatever the tach maxes out at when you throw a brick on the pedal should be a safe max allowable rpm.
hell my 390 will rev 5500 all day no problem. Under extreme acceleration the tach has occasionally said 7000-7500, maybe even 8000, no problem. I am not sure if that is actually true, or if the needle is just over-swinging. I almost think it's true. she gets wound up pretty tight.
This is what happens when you floor it, with a C6... When I hold it down and dont let up, it shifts into 3rd at 80, and hammers hard. my dad's big LTD is about the same.
I seriously wish I had some more gears.... Anybody want to make a collection pot so that I can get a xmas present from Tremec this year?
Well I went out camping this weekend. I pulled the scotty with the truck,which wasn't all that bad. But what loaded it was all the stuff extra we took. Enough foldable chairs for all of Elizibeth Taylors wedding guests, Enough supplies for the invasion of some third world county and all the electronic gadgets my girl brought that I thought was one thing you got away from camping. We were full. Then to top it off we went to a state park that was up hill all the way. It was about 2 degrees short of the same angle the apollo rockets took off from. I was afraid we would flip backwards it was so steep. We went quite a few miles. Anyway I had it to the floorboard reving at about 3k I think and it was going up as fast as it could. It was probably 20 mph. It was a steep long hill. The park and the road to it was around and up a mountain. But it made it fine. On the way home it ran better since the hills were not as steep going back. It was constantly up ,down, up,etc. So I guess if it can take that it should take any normal driving I do.
blackagatha
like this.... The Little Car That Couldn't
