Backfire when accelerating from 40mph to highway speed
leftside11
Post by leftside11 »
Hi all,
Slick is choking when I attempt to get up to highway speed. Where should I start to look for the problem?
Also what type gasoline are you using to filler up?
What weight motor oil is recommended for the upcoming summer?
Thanks in advance
36truck
Post by 36truck »
Check your power valve & accl. pump on the carb. 10W40 motor oil. Standard rebuild engine regular gas works a hotter engine use premium gas.
Tom Williams
racerx1699
Post by racerx1699 »
What motor and trans do you have?
1. Points and dwell
2. timing
3. Carb
4 Fuel filter
Gas could depend on your motor, I would think reqular would be fine
Oil could depend on your location, I live in Maryland and run 10w 40 all year.
Hope this helps some.
Donnie
2011 F150
32 Ford Coupe
1985 Mustang 10.50's 1/4
1997 F350
If it wasn't on 8 Track it's not worth listning too
blackagatha
Post by blackagatha »
take the vacuum advance hose off the carb and suck on it, if you get a mouth full of stinky air you got a bad advance... that sounds like a likely culprit.
if you dont get a mouth full of stink air, still pop the dizzy and check that the advance moves the breaker plate when you suck. it might be stuck.
