I'm looking at buying an 86 F150 2wd basic long bed truck. it has a 300 (4.9l) 4 speed manual. Are there major trouble spots I should keep my eyes out for when i go to look at it?
this is the listing
http://maine.craigslist.org/car/686292339.html
It looks like all the right things have been replaced but I'd like some real experience with these years/engine before I went. Thanks guys and gals.
86 F150 questions
- slickmainer
86 F150 questions
--Gregg--
you can't get there from here
i'm about to get one with electrical problems... i'm guessing it's either on ignition switch or in the firewall area.. from what i've read. they're good trucks overall, just bad year for computers. this is my $0.02
-andrew
-andrew
1966 ford f100 - project on hold for now
1970 ford f100 - dd
1977 international harvester scout 2 - MUD
1970 ford f100 - dd
I used to own this '82 F150 4x4 6-banger. Bought it for $300 with a dead engine...rebuilt the engine, put in a heater core & drove it for 2 years. It was a good truck overall, but that's about as close to owning an '86 as I've been.
- slickmainer
- Johnny Canuck
Garbz
86 will still be carbed with a YF carter feed back unit. There is also a rudimentary puter under the dash to make it work. A real pain tin the arse to trouble shoot.
If it runs rough and stumbles it is probably the carb base gasket as they are notorious for vaccume leaks and are a bitch to fix.
The nuts you see don't tighten it...LOL it has a sub base and hidden bolts, Mostly why people give up on them.
Also look at the rear frame hangers for the leafs as they tend to disappear in north eastern climates. Also gas tanks are prone to rust.
I drove my 86 extended cab F150 300ci 4x4 Goat truck 300K+ miles...
Garbz
Garbz
- slickmainer
When I went back to look at the truck a second time the guy decided not to sell it. He said he didn't want to part with it. I only had $1500 and up here, 90% of trucks are up in the $2500 range or in the $200 range and need $2000 worth of work and need to be towed. I didn't have either of these.
So I went with what I had access too. I put functionality before loyalty in this case. There is a whole market of people going down south buying cheap trucks and bringing them to new england/ Maine and suddenly they are worth $1000-$1500 more.
--Gregg--
