Looking for a tool
61ford
Looking for a tool
Post by 61ford »
anyone know of a tool that will let me get into tight corners and grind welds?cant get in there with my grinder only uses up the tip of my discs and accomplishes nothing
Ryan
61 Ford f100 Unibody short bed
351w/Aod
If you have a compressor try a die grinder. If not you may try a Dremel tool (similar concept but electric) which also has an optional flexible extension kinda like a dentists drill. I have a pretty extensive setup with mine.
http://www.dremel.com/en-us/Tools/Pages ... x?catid=13
shawns fords
Post by shawns fords »
I have a straight and a 90 Degree angle grinder. they both have worked into tight places, I also use cutoff wheels, but when I cant I use a set of matco tools carbide tip grinding bits, they will cut through anything and are small and have many assortments of shapes to accomodate anything your going through. I have had that set since 1992 or 93 and still use them today
this is the good side
dropped64
Post by dropped64 »
hot knife
projects,
64 f-100 will have ifs bags 4link and (dont hate me i want to keep it i6) rb25det from nissan skyline
79 f-150 supercab shorty currently 460 will be 383 from roadrunner (use what you have)
67 f-100 saved from stupidity no rust willing to sell
79 trans am 60k built 403 sold it!!
96 nissan 240sx in the process of gettin an rb25det conversion
my driver 88 jeep cherokee with 235000 miles!
61ford
Post by 61ford »
a hot knife? ive got a die grinder ive been looking for those tips youre talking about but never can find any grinding dics all they do is hit the areas above and below it u can turn it on its tip and get a little but not really
Ryan
351w/Aod
dropped64
Post by dropped64 »
an oxy-accetelene torch
projects,
dropped64
Post by dropped64 »
dont worry im just kidding
projects,
