Valve Knock
Valve Knock
My truck developed a tapping sound comming from the drivers side valve cover. It only does it when it is warm, and it gets faster a i rev the engine. Is it a valve knock or something else and how so i correct it??
-1966 Ford F100, 352, 4 speed, smoke grey, mustang buckets
-2003 Ford Ranger XL, 3.0, 5 speed
-1989 Ford F250, 460, highboy, 4x4
shawns fords
If you start it for a very short time with the cover removed it will be messy but you might actually see whats going wrong too. If a rocker is the culprit its probably actually the push rod. Rockers don't just come out of adjustment. It happens more slowly due to wear. If it happens all of a sudden there is another problem. Generally the push rod bent/failed. They too can fatigue and fail after a certain age and enough Hot / Cold cycles.
" You can fix anything with Duct tape, Bailing wire and a welder ! "
shawns fords
I dont think he will actually need to start it, thats a last resort lol. just look all the valvetrain over closely, and can turn it over by hand with the crankshaft bolt and a socket. or have someone bump the starter a few times to see if everything is moving smoothly. I always made good practice to put each cylinder at TDC for these diagnostics and check play in the rockers as I go from cylinder to cylinder. Usually if a valve gets caught up inside its chamber somehow, either due to carbon buildup, or loss of lubrication and seizure then the pushrod can get bent. I would guess the 352 is a shaft rocker system with non adjustable rockers ( hydraulic) so check the bolts on the shaft also
this is the good side
