Dakota install finished!! (dial up beware)
jecsd1
Post by jecsd1 »
I finally got the install complete. All I'm missing is the rotors and calpiers. I installed polyeurethane suspension bushings in place of the old sloppy rubber.
After finishing I was in such a good mood that I yanked the rear axle out to get after refurbishing it. Anyone have any rear suspension ideas? I know I can always redo the stock equipment but the frt end is supposedly gonna handle great. I would like the rear to match. Thanks, Enjoy!
Phil
Post by Phil »
Very nice looking job there! As Heavy's pic suggests, add a sway bar & you should be pretty happy with it.
Phil
Post by Phil »
Greg D wrote:Very nice looking job there! As Heavy's pic suggests, add a sway bar & you should be pretty happy with it.
flipped axle too
PS very nice job!
lefty
Post by lefty »
yea, what they said!!
Looks great! That truck looks like its in real good shape too.
'61 Uni SWB BBW Custom Cab 302 T-5 w/ Power brakes
It ain't pretty either!
Slick Fan
Post by Slick Fan »
Man, that looks pretty darn schweet! :thumright:
I just wanna know how many times you whacked your head on those hinges?? :lol:
jecsd1
Post by jecsd1 »
I must have hit my head 3 or 4 times. The hinge bolts are stripped and I haven't figured how to get them out w/o destroying things.
HeavyHauler, who makes that sway bar kit and brake setup are you running. Those rears look nniiiicccceeeeee..... I am still hunting for rear brake/master cylinder options.
oh yah, are those stock rear leafs?
jecsd1 wrote:I must have hit my head 3 or 4 times. The hinge bolts are stripped and I haven't figured how to get them out w/o destroying things.?
JC was the last one too over come that problem!
and I agree with the others re the rear end, but use a DJM drop kit to lower it,. the front end looks like a bought one! NICE work 8)
Alan,
UNIFAN
Post by UNIFAN »
I agree with Heavy on flipping the rear and I have used a sway bar setup off of a MK VII rear and it works great with some energy suspension end links if it worked out to be easier and cheaper.
Ford_in_Montana
Post by Ford_in_Montana »
So what's the bolt pattern on the Dakota front end? Can you still use your original rims or do you have to score some new ones?
Why do Chevy engines have so many aftermarket parts available?
BECAUSE THEY NEED THEM!!!
Phil
Post by Phil »
Guys said summit
and all stock susp just flipped
MadMaxetc
Post by MadMaxetc »
Ford_in_Montana wrote:So what's the bolt pattern on the Dakota front end? Can you still use your original rims or do you have to score some new ones?
If you use the 89 rotors you can get 4.5 x 5. Not stock, but it does open up your rim choices. If you want 5.5 x 5 you can have the 89's redrilled.
Nice work on the install. I need to get my ass in gear and get mine put in!
My Build Thread
Hoofbeat Racer
Post by Hoofbeat Racer »
Great job on the install, it looks awesome. Nice straight looking slick too 8)
this would compliment your front end work nicely. I installed this setup with leaf spring floaters on mine. I guess it depends how much you want to hook up. :lol:
http://chassisengineering.com/shopDetai ... uctId=1392
After Backyardresto's issues with DJM, be somewhat leary. I used Belltech drop hangars and they seemed ok.
If you want disks in the rear, the Lincoln Versailles is a 9" option.
Mark
MadMaxetc
Post by MadMaxetc »
Hoofbeat Racer wrote:Great job on the install, it looks awesome. Nice straight looking slick too 8)
How do the floaters install? I can't picture it in my head.
My Build Thread
Hoofbeat Racer
here's a picture of the floaters Dan
http://chassisengineering.com/shopDetai ... uctId=1148
Basically, the brackets get welded to the axle tube and the leafs sit inside on the rollers. In order to transfer all torque through the ladder bars, the U-bolts must be removed from the springs so they just "float". Not to mention the fact that with changing the pinion angle via the front mount on the ladder bars, the springs must be able to roll somewhat. Hope that makes some sense.
The picture shown on the linky would be for an under the axle mount similar to jecsd1 setup. Hope this explains it
Mark
johnny
Post by johnny »
looks very nice that is a great looking set up, on my 65 i flipped the axle and c notched the frame also took out a spring or two to get the back down the way i wanted , the front i used MII with dropped spindles and stainless A arms top & bottom
2) 55 f100's
2) 65 f100's
and all the other ford trucks my wife doesn't know about!!
MadMaxetc
Post by MadMaxetc »
Hoofbeat Racer wrote:here's a picture of the floaters Dan
Ya that does make sence. How would that hold up to the 600ft-lbs I am going to have from my 5xxcid bored out 460?
My Build Thread
Hoofbeat Racer
I think it should stand up OK, I trust it with my big block. Will let you know though, us garage queens :wink: are slow to get our projects on the road :lol:
Mark
