John
351 cobra jet
351 cobra jet
A buddy of mine at work had a 55 f100 w/utility bed on it that burned up in fire
he wanted it out of there and know im into those so he gave it to me said it came with a cleveland motor and 2 c6s so i picked it up and pulled the engine tranny and any other parts i could use then junked the rest well started poking around cleveland web sites and looked at the casting #s and looks like i now have a 351 cleveland w/4v heads hence a cobra jet engine i hear the only bigger heads ford made is for the 460 police interceptor, the 4v heads flow more and have bigger valves then all other ford motors with the exception of the 460 pi motor would like to put the heads on a 351 windsor and make a clevor motor has any one done this ?
John
John
2) 55 f100's
2) 65 f100's
and all the other ford trucks my wife doesn't know about!!
2) 65 f100's
- Alan Mclennan
John, it sounds like you should just go for the 460, and not the pissy little 351 Clevo!, and just to help you out if you bolt the c6 to it as well, I`ll send over some stamps and my address. I dont mind helping you out that way!
Alan,
Alan,
BackyardRest
Re: 351 cobra jet
There is a CJ 351 & a 4v 351 Cleveland. The engine you picked up could be either one but would depend on a few things. There was also a 351 Boss. Is it a 4bolt block? what are casting numbers and date codes of heads, intake and block? The cleveland ports are a fair amt bigger than the PI 460 or PI 429. There is also a 429CJ and SCJ version that have much larger ports than the 4v cleveland/CJ. The 351CJ's were 72 versions, also a HO version 351c.johnny wrote:A buddy of mine at work had a 55 f100 w/utility bed on it that burned up in firehe wanted it out of there and know im into those so he gave it to me said it came with a cleveland motor and 2 c6s so i picked it up and pulled the engine tranny and any other parts i could use then junked the rest well started poking around cleveland web sites and looked at the casting #s and looks like i now have a 351 cleveland w/4v heads hence a cobra jet engine i hear the only bigger heads ford made is for the 460 police interceptor, the 4v heads flow more and have bigger valves then all other ford motors with the exception of the 460 pi motor would like to put the heads on a 351 windsor and make a clevor motor has any one done this ?
John
The Boss 302 also had large 351C style heads.
the date codes and casting numbers will determine which engine you have. What intake manifold? cast iron or aluminum?
BackyardRest
DangAlan Mclennan wrote:John, it sounds like you should just go for the 460, and not the pissy little 351 Clevo!, and just to help you out if you bolt the c6 to it as well, I`ll send over some stamps and my address. I dont mind helping you out that way!![]()
Alan,
An Aussie NOT opting for the Cleveland?
I'd run the Cleveland as is. A Boss requires too many mods. I can't even find a machinist near me that can do a stock 460 w/o f'ing it up and I live an hour from where they were invented.
Actually though that engine is made for top end RPMs.
Usually not where you want your power in a truck
Someday I'll get another slick
Had a 70 Mustang with the 4V heads, real lazy on the street......until you made some RPM. Felt like trying to put around on a 2 stroke dirt bike. I agree with BYR, a mild 460 with some port matching makes for a sweet street motor that would prbably blister a streetable 4V motor. Or build a Windsor with some of the later aluminum heads that are so plentiful nowadays. Clevlands are cool but I feel there are better alternatives. Now you got my 2 cents worth.
- Hoofbeat Racer
Jeepers Randy, one day I'm going to go for a drive and come visit this museum of yours that houses all of this FOMOCO pornography.BackyardResto wrote:forgot to mention of you want to do a nice 460 I have a set of virgin 460 PI heads waiting for a new buyer.....
460 would be a much better choice than the cleveland
You know what I mean, the stuff that we only fantasize about but is unattainable. ex PI heads, Boss 302s, 427s, etc
Mark
BackyardRest
Always here so drop by anytime! loflolHoofbeat Racer wrote:Jeepers Randy, one day I'm going to go for a drive and come visit this museum of yours that houses all of this FOMOCO pornography.BackyardResto wrote:forgot to mention of you want to do a nice 460 I have a set of virgin 460 PI heads waiting for a new buyer.....
460 would be a much better choice than the cleveland![]()
- Alan Mclennan
Dang nothingHeavyhauler wrote:DangAlan Mclennan wrote:John, it sounds like you should just go for the 460, and not the pissy little 351 Clevo!, and just to help you out if you bolt the c6 to it as well, I`ll send over some stamps and my address. I dont mind helping you out that way!![]()
Alan,![]()
An Aussie NOT opting for the Cleveland?![]()
I'd run the Cleveland as is. A Boss requires too many mods. I can't even find a machinist near me that can do a stock 460 w/o f'ing it up and I live an hour from where they were invented.![]()
Alan,
