AC problem question
willy3486
AC problem question
Post by willy3486 »
This is for the AC people out there. I think it is a problem that a AC person would know quickly. My wifes car and my truck are doing the same thing. When you pump down the lines or in other words vacuum the lines out it pumps down fine. Then when I put the freon lines on the freon won't go in and the pressure on the low pressure line is about 100 psi. So I am wondering is this the pump or some other issue? I put the freon on the correct side since the high pressure is a different size fitting. Any suggestions ?
are you trying to charge it while its running?
the low side pressure will drop down to around 30psi
when it is running
when not running the high and low are the same psi as
the freon in the can.
johnny
Post by johnny »
dont you just put the windows down and vents open and drive 65? :hm:
2) 55 f100's
2) 65 f100's
and all the other ford trucks my wife doesn't know about!!
willy3486
Post by willy3486 »
I try it when it is running so it should hit around 30 and not the 100 that it is doing. Its doing it on my daily driver truck and my wifes car not the slick. I thought if I could figure it out I could fix them. I have a car that the parts would work on my wifes car I could get the parts off of. It has bad seals on it I never fixed. I thought if it was the compressor I could get the one off the junker before I got rid of it.
The Big M
Post by The Big M »
I'm thinking there's a restriction in the system somewhere. Maybe a clogged condenser, collapsed hose, or bad expansion valve/orifice tube. What year/make/model are we talking about?
willy3486
Post by willy3486 »
My wifes car is a 98 caviler and my truck is a 91 mazda b2200.
may be the dryer clogged
thats the thing that is about the size of a soup can
if you change it youll need to pull a vacume
