Question on my 78'
66fordtrucknut
Question on my 78'
Post by 66fordtrucknut »
Since there isn't a site worth a hoot for dent's I'll ask here. My 78' has two tanks, either the switch on the dash or the valve isn't working. what would be best method for testing which one would be the problem?
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
36truck
Post by 36truck »
Check electric out first if power is at the valve then new valve time. If no power start at the power point and follow it back.
Tom Williams
66fordtrucknut
Can I just use a test light? My multi meter took a dump.
62' SWB uni 223
36truck
Post by 36truck »
If you do DON'T poke the insulation of the wire.
Tom Williams
Johnny Canuck
Post by Johnny Canuck »
Charlie I think a test light would work. I am betting it is the valve, those things used to regularly take a dump. I think almost everyone I ever knew with a 78-79 with 2 tanks replaced one.
Mine only had single tanks. Never seen one where the switch went, but there are exceptions to every rule.
Missed ya at SS this year bud.
MrEvil
Post by MrEvil »
JC is right, both of my dad's '78 Dentsides have factory dual tanks (F250 4x4 and F350 crew) and according to him the valve has always been the problem with those trucks. When my dad first got his 350 crew cab he had to make sure both tanks had gas in them because the valve would get stuck halfway and cross-feed between the front and rear tanks. The '78 4x4 was the same way when dad took the truck off Propane and back to gasoline. Both of his '79 Dentsides (F150 supercab and Bronco) are just single tanks, though he did put an aftermarket rear tank on the F150, but it's used as "Get you to the next station" gas since it doesn't have a gauge.
Vehicles:
2000 F250 Superduty Crew cab
1998 Ford Crown Victoria Police Interceptor(work beater)
1961 F100 Uni (my baby)
1966 Thunderbird: someday.
66fordtrucknut
I need to replace the main tank, I dropped the aux. tank and it's still in good shape but it wouldn't switch tanks so I bypassed it (the valve) but I want to fix it right, JC, I missed everyone there too, wasn't planning on using up my vacation time with gallbladder surgery back in June. Hindsight, it was worth it. Been putting it off since SSII, it got too bad.
Charlie
62' SWB uni 223
