Problems with my 71 F100
dotcentral
Post by dotcentral »
Don't know if I have ever mentioned it here, but my 71 351W/AOD has a vibration issue. The engine was gone through before I bought it. It is a 86 or 87 Bronco block, mostly stock, came out of an early 70's Mustang. I drove it in the Mustang, with a toploader. Ran great. Someone buys the Mustang, has it a few months, but decides they want a Cleveland. So, I buy the W, put it in my 71. Now it has a vibration at about 1700-1800 rpms, that seems to come and go. I never noticed it in the Mustang. Basically, runs smooth until 1700 or so, then every 4-5 seconds, I get the vibration. It is there in Park, Neutral, drive. Sitting still or coasting in neutral or in gear.
I've had the AOD checked twice, checks out each time. Same with U-joints, also traded tires & rims, driveshaft rebalanced, rear axle checks out.
I have tried both new AutoZone & Ford flexplates (For a F150 351W/AOD), no difference. I tried a new aftermarket harmonic balancer. The vibration is now less severe, but is constant at about 1200 or so RPM.
I really think it is the engine. A rod or the crank is bent, or something internal to the engine. The person that bought the Mustang has a teenage son. I wonder if one of them did something to the engine, and that was the reason for going to the 351C. But, I can't totally rule out the converter.
My next step will be one of the following. I think.
1. swap torque converters.
2. Go for a used 302 or 240/300 6. Maybe get a FI 300 and a T-5.
I am considering put a 6 in my 71, and say forget it to the W. This engine idles great, but this vibration is stopping me from finishing this truck. All it needs is some minor bodywork, the interior installed, and paint. My wife wants me to sell it and concentrate on the 66, but I have so much money in the 71 I'd never break even. Plus the 71 rides better than most new longbeds to me. It goes down the road nice, just has that vibration.
Does the engine have a balanced damper on the front? Pretty sure your 351 W will. These usually have a 2 separate metal parts with rubber cast between them. Sometimes the outer weight ring can slip and cause vibration (not to mention premature bearing failure). You might try checking it out. Only thing is replacing it is about the only way to know.
dotcentral
Yes, brand new, aftermarket harmonic balancer or vibration dampener.
FORDMANLCRACKEL
Post by FORDMANLCRACKEL »
If it came from a early 70's Mustang it will have 28oz balance. The newer 351w has 50oz balance flexplate. I'm not sure what year the change was.
Lonnie
dotcentral
It has the correct 50 ounce flywheel for a 351W. I started with a brand new advance or auto zone (pioneer brand), then went with a new Ford flywheel, which I have on it now.
Garbz
Post by Garbz »
Your trucks small block was placed on the old FE I6 mounts? A common mistake as the small block will bolt to the I6/FE mount.
If so the engine is 1" too high and out of line/phase with the rear axle. Causes buzzing at certian RPS all the time under acceleration and under deceleration.
Garbz
Garbz
Post by Garbz »
Garbz
''It is there in Park, Neutral, drive. Sitting still or coasting''
i doubt if its in the drive shaft , i would think its something that
is attached to the engine , alternator, waterpump, radiator fan...ect
dotcentral
Garbz, I will measure them and compare to the FE mounts in my 66, but pretty sure I am using the right ones.
Slick4x4, that is something I could check. I could undo the accesseries and brackets and see if it goes away. I may have an old waterpump somewhere, but it would be easy enough to take off the alternator and power steering pump.
thanks for the ideas on what to check.
