Steering Columns
63ghost
Steering Columns
Post by 63ghost »
Hey Guys, Does anybody know where I can get a tilt steering column automatic for my 63? Also is there a easy way to take the em. brake handle out without cutting the cable? feedback.gif
First of you need to have the ability to cut and weld or grind a flat on your present column, it is a 1 piece shaft mounted in the box. After you get a rag joint plate on the stock column then you can use whatever will work for you pretty much. Scrounge the yards for one or get a Flaming River or IDIDIT type column. Lots of options really. Be warned, unless you convert to power steering your steering effort will increase with a smaller than stock wheel.
Garbz
Post by Garbz »
The e brake cable is removed by pulling the pressed in pin that you see sticking out of the pull shaft.
The pin once puled allows the shaft to be rotated to the correct position to remove the ball end of the cable.
Garbz
