Well Iceman and all the others thanks for the advice. I got another thermostat for my daily driver this week. I wanted to replace the one I put in last week. I tested it first as suggested and it opened fine when I put it in water on the stove then heated it. I took the old one out. Before I put the new one in I tested to see how tight it was compared to the one I pulled out. No comparison, the one I put in last week I couldn't hardley open and the one today I could. I put it in with the hole and pin towards the top so air could release. I would have drilled a hole but this hole and pin took the place of that. I put it all back together then I poured antifreeze into the top hose. I then worked it down to the radiator. then started it and let it run a few minutes. as I did that I poured more antifreeze into the radiator until it wouldn't take any more.
Then I shut it off and let set for a while until itcooled enough to take the hose off the heater and let any air out there. I put it back on and hit the road. I did notice this was a 180 degree and as suggested I made sure it was one made in the USA. The other one was a 195 degree . When I took off I went down a backroad by my house. Usually when I start my truck to go home or leave it is a few minutes before I can get up to speed, in the morning the transmission and engine have to warm up and the afternoon I have to go through redlights. Well it did get hot for the first few minutes or about 70% up the gauge. It has not ever got to a dangerous hot I don't think. Then after about 5-10 minutes it cooled down to halfway or less,where it ran when I first got it. From the make thats about where it should show on the gauge. So I went to town and out through the countryside. I drove for probably a hour or longer just enjoying rock from the late 70s and early 80s on my cd player and also the fall colors. The weather was great also . After driving like that and it no longer goes more than half way I think it is resolved. But this truck has a way of going gotcha so I will watch it for a few more days cautiously.
So guys thanks again.
thermostat issue resolved , I think
glad to hear that
i had fun with thermostat yesterday too on my wifes 66.
was installing a block heater and new thermostat, old was 160, new 195.
5 lbs of permatex on gooseneck and thermostat could not figure out why.
turns out aftermarket gooseneck does not have same amount of stock around bypass hole and gasket has extra large hole for bypass so i ended up making my own gasket.
the 195 is a big improvement, much warmer in cab and engine is running better, with the 160 it would only show around 140-150 on the gauge now its right between 190-195.
This is the one I pulled out of my little Dodge Shadow daily driver last spring.
It suddenly stopped warming up one day, the gauge stayed at the bottom & no heat through the heater. I double checked my coolant level, it was full.
I assumed the thermostat had stuck open, but it was mid December & there was no stinkin' way I was messing with it in 15º weather if I didn't have to (I hate the cold
), so I covered half the radiator with a flattened Budweiser box & wa-la...HEAT!
On extremely cold days, I'd cover more of the radiator...on warmer days, I'd have to move it to the side to allow more cooling.
What's odd is that it's stuck closed in that pic, but I guess with the spring bracket broken like that, maybe there wasn't much tension on the spring & the pressure of the coolant flow just pushed it open as it went. Beat's me.
