slick oddities
Converting my Uni to a panel was the first thing that went through my mind when I got it home. I never completely forgotten. Posting this has got the juices flowing again on it.
Slick Fan
Post by Slick Fan »
Greg D wrote:Converting my Uni to a panel was the first thing that went through my mind when I got it home. I never completely forgotten. Posting this has got the juices flowing again on it.
I bet that if you used the roof from a van, some of the flat side sheetmetal from the van & slid the Uni's back window to the back, it would look purty good. Just don't know how to do the rear doors, is all. :hm:
There are 2 ways to do the rear door (s).
1. Using side opening van doors refab them to work in the Uni, hinge placement will be a challenge.
2. Some old panels had a tailgate that opened down like a truck with a window door that opened up like a 50s station wagon.
The latter would likely work the best because you wouldn't be changing the tailgate too much. It would also allow keeping the lip at the back of the roof and the stock rear window. Hinging would also be much easier without looking horrid. If I were to go that route I would likely make a smooth tailgate similar to Mike Kimbrel's, it would go with the upper sections lines better. Gas tank would need moved to under the bed floor and would need an outside filler, a true panel would be open all the way through. I would be moving the back of the roof to the rear of the truck anyway. The trucks roof would likely need cut out fairly close to the front to achieve a smooth line all the way to the back. Not exactly a weekend project but very doable. I would do one with no side windows. An old van roof would be just about right. One issue I do see that needs sorted out is the roof section itself. Ideally mine would not have ribs so for it to not buffet in the wind and be stiff it would need alot of inside reinforcement. I should likely buy a good wire welder if I do this, and stock in wire, lol.
Slick Fan
Post by Slick Fan »
I agree, a panel truck NEEDS to have no windows. 8)
Overall, I think that using a ribbed van roof would be best for two reasons. 1) Would help cut down on vibration issues, like you said. 2) Getting a wide, flat piece of metal that long to look smooth would be a major PITA. Just thinking that ribs in the panel would help hide some of the minor imperfections more easily.
The station wagon style rear window would probably be the easiest & cleanest looking style to use...someone needs to photoshop us some pics. :lol:
BarnieTrk
Post by BarnieTrk »
I'm not sure how odd, but this is the first for me to see one of these --
http://groups.msn.com/slick60sfordfseri ... otoID=5412
So - was that 'big window' Slick a home-grown custom, a Crown or other aftermarket conversion or an obscure FOMOCO option?
BarnieTrk :)
jkimbrel65
Post by jkimbrel65 »
Thats Chads aka 1st64bigwindow out of York Pa.Story I got was they were sitting around drinking some beers and... :rotflmao: Nice custom job. Looked it over several times,Him and Chuck did good.Rumor has it theres another one somewhere in Canada whistle.gif
I tried being normal once...
BarnieTrk
Post by BarnieTrk »
jkimbrel65 wrote:Thats Chads aka 1st64bigwindow out of York Pa.Story I got was they were sitting around drinking some beers and... :rotflmao: Nice custom job. Looked it over several times,Him and Chuck did good.Rumor has it theres another one somewhere in Canada whistle.gif
Want to see another big window?
.....How about a UNI ?!
Check it out here: http://groups.msn.com/slick60sfordfseri ... otoID=3381
BarnieTrk :)
jkimbrel65
Big windows where 61-63 uni only.Chads is a 64 custom job he and his dad did 5-6 years ago
BarnieTrk
Post by BarnieTrk »
jkimbrel65 wrote:Big windows where 61-63 uni only.Chads is a 64 custom job he and his dad did 5-6 years ago
Mike,
Thanks for the explanation ! :thumright:
BarnieTrk :cheers:
BigTim
Post by BigTim »
jwh f-100 wrote:Effie, That thing is cool!!! Is it set up so the Bronco cap/top can be installed on it????? I had a '79 and later a '93 Bronco, miss them both..
I have been gojng back and forth on wanting a Uni and a Bronco, that could be the solution. :D
Truckfarmer2
Post by Truckfarmer2 »
Greg, the early Econolines (61-67) used the same doors on the sides as the rear. They will interchange. The early Econoline roof is not ribbed but has two indentations, similar to the 64-66 Slick roof. So most would think it is stock Ford.
If you cut up an early Econoline, grab the gas tank. It has the same dimensions as the Mustang tank that some here have adapted to their Slicks, except the van fuel filler is on the side instead of the center of the bed floor.
If you continue to buy imports, where will your children work?
jwh f-100
Post by jwh f-100 »
I agree. A full size bump-side bronco would also make people scratch there heads and may be fairly easy to line up the roof/tailgate sections needed.
Jason
Beer will change the world.
I don't know how but it will.
A full size bump Bronco would be pretty easy as far as customs go.
fmartin_gila
Post by fmartin_gila »
We had a couple of those HydroCrane's years ago where I worked, and as stated, they were a real workhorse. Looks like they are still using that one.
In the mid 60s, GM put out a Suberban type that had a raise-up window and a lowering tailgate. Another place I worked at, we used a 57 or 58 Ford Courier as a service vehicle, and I think it had a rear set up the same way.
Fred
