Garage Lighting Question
I am almost finished with my new garage (20X20 with a 10 foot flat roof). I'm trying to figure out what kind of lighting to use to give me the most light at the lowest cost. I'm thinking of using 4 to 6 "shop lights" (ie: 48", two bulbs, pull chain) which I can get for less than $20 each. Does anyone know how much wattage/lumens etc I would need for good lighting?
While writing this I googled "shop lights" and came up with this from Northern Tools: http://www2.northerntool.com/lighting/h ... 162197.htm $20 each and 500 watts. Sounds like a lot of light at a low cost.
Any thoughts?
Any thoughts?
yes the opposite of me, flourescent lights wont start in the cold.ok if you have a heated shop or above freezing.36truck wrote:Halogen lights give off lots of heat & where you live that is a bad thing. Florescent lights work good for what you need.
i need either halogen or h.i.d
the metal halide like in this ad would be good for me.
http://anchorage.craigslist.org/mat/909884524.html
Actually Tom, the heat would be welcome today. It's 47 degrees and damp (I know, I know, that would be summer temps for many of you guys. I've turned into such a wimp in my old age).
I really need to know how much light I am going to need? It's been a long time since I've had a garage and I'm having trouble visualizing the effect.
Grits,
I added an outlet to my ceiling that is controlled by a switch. I then added four 4' florescent lights over where I work on the slick. The four lights work great. I think I spent about 60 bucks at "Home screw ya" for the lights and the bulbs. If four does not do it for ya just add a couple more. Congrats on the new garage.
Jason
Beer will change the world.
I don't know how but it will.
- PFM-64f100
I run the big 8 ft Fluorescent work lights. At Home depot they have a cheap version that will do (2) 75 watt Slimline lamps . Gives off plenty of light. They do take a little time to get bright when it's really cold but doesn't take them long. Now if you are in the frozen north that's a different story.
I installed mine 3 or so years ago and still have the orginal bulbs. I currently have 6 of them in a 30 X 40 shop (normally only use the main 4 unless I am doing a lot of work). I wired a switch to them it's really easy to do. I think they cost me $30 bucks each plus blubs, looking at the web site they don't list the 8 ft light I have but I know the store has them.
They don't cost much to run and give off plenty of light. That's my
I've got two little 60 watt incandescent bulbs wired to a switch beside the man door. Those are used most often, when I need enough light to walk around in the garage without bumping into things...cheap light & and they light up no matter what the temperature is.
Then I've got two 8' flourescent lights (65 watt, if I recall) on the high part of my ceiling & three single bulb 4' flourescents under the loft. The 4' & 8' sets are switched independantly of each other, so I can control how much power I'm wasting.
Helps the flourscents last longer too, if they're not flipped on each time someone walks into the garage.
Once those lights are all on, it's pretty much daylight in there.
I have a 30X36 Shop and I have 12 4 ft, 4 bulb flourescent lights up and I sometimes don't have enough light. As far as I am concerned one cannot have enough light. I got lucky a couple of years ago and bought these and many more at an auction. I also got 2 pallets of bulbs. Everything I got that day cost less than $50.00. I still don't have a clue how many bulbs are left. Probably enough to last me the rest of my life.
I know what you mean...especially with my "elderly" eyesight.oldtrucks wrote:Gritsngumbo: As far as I am concerned one cannot have enough light.
gritsngumbo
http://s214.photobucket.com/albums/cc19 ... 60%20Shop/
This is an older album but you can see pretty much how it looks mess and all
Being vision challenged too there never seems to be enough light.
- ezernut9mm
brian, a friend had one of those in his shop and it doesn't put out as much light as you would think. plus every thing looked wierd in that light.ICEMAN6166 wrote:yes the opposite of me, flourescent lights wont start in the cold.ok if you have a heated shop or above freezing.36truck wrote:Halogen lights give off lots of heat & where you live that is a bad thing. Florescent lights work good for what you need.
blackagatha
we got 3 sets of 8 foot fluorescents in each half of 4.5 car garage. Decently bright for most purposes, then we got a 4 footer that we can move around. Still wish we had more sometimes, but generally more than enough.
I just wish I wasnt being such a moronic kid a while back. I noticed that you can see the receding glow when they turn off if you look away then straight at them right after you kill the switch. It looks really cool. Well, me being a retarded 8 year old at heart had to flick the switch a couple times, and blew up the ballast in the one over the work bench.... I need to fix that while I'm home....
Truckfarmer2
I have 2 500 watt halogen fixtures in my shop. Those are for a quick trip in (don't have to wait for the flourescents in winter) or special jobs that need more light. I have some 2 bulb, 4' flourescent fixtures and then bought a 8' fixture. I am amazed at how much more light the 1 8 footer will put out more than 2 4 footers next to it.
Helpful tip: when you wire the lights, use a separate circuit so if you blow a fuse, you are not stumbling around in the dark.
If you continue to buy imports, where will your children work?
Thanks!
Thanks guys for the info and the advice. Typically I am more confused than when I asked the question. Information overload I guess. Just will have to narrow the choice down to price and effectiveness.
I ran across an article written by a guy named Jack Lindsey on Lighting a Workshop. Pretty good information. It is written for woodworking shops but the info should be valid for out usage also. I have attached a link:
http://books.google.com/books?id=aKBYFp ... t#PPA70,M2
This links to a Google Book Review site so you can read the article. Page numbers are: 68-74.
Looks like I would need 8 eight foot two bulb florescent fixtures to give optimum lighting in my shop. For the price and the output, I'm still considering the 500 watt halogen fixtures from Northern Tool, despite the heat (doesn't heat rise?). I also like having the pull chain on the fixture so I can turn them on or off as I need the light.
Truckfarmer2 wrote:I am amazed at how much more light the 1 8 footer will put out more than 2 4 footers next to it.
Grits, if I were you, I'd only buy 3 of the 8-footers to start off with & hang them in a temporary fashion, to see what you think. My garage is a 20x20 too, and seriously, two 8-footers light mine up real well.
If you decide that you need more light, then go back & buy some more. I'm just thinking it's easier to do it that way than try to return them if you don't want them.
That makes a certain amount of sense. Thanks.
