JOEY
SCORE!
- therealjoeshmoe
SCORE!
OK I LUCKED OUT A LITTLE AT WORK TODAY.. i HAD SPECIAL ORDERED A DOOR POPPER KIT FOR ONE OF MY CUSTOMERS AND THEY REFUSED IT WHEN WE TRIED TO DELIVER IT... BROUGHT IT BACK AND DISCOVERED THE BOX WAS PRETTY BIG SO I OPENED IT UP. IT HAD THE DOOR POPPERS, ACTUATERS, MOUNTS, BRAIN AND KEY FOBS.. SO I ASKED MY BOSS IF I COULD JUST BUY IT FOR COST... AND WAAALAA GOT EM! NOW OLE RED IS GONNA GET SHAVED DOORS!
JOEY
JOEY
- 6166 Junkyard Dog
Past exp.... shaved handles might look nice but not wise, have on my 56 and wish as never done power goes out your screwed so better put a back up in, next as hard it is to sometimes slam doors to get to shut, on my 56 one door cracked real bad where the handle was and used very little filler still cracked and welded plate to cover handle in past years have seen many rods cracked where the handles where daily driver no way,,, Trailer Queen go for it ,,,,,,,,, just my
i
Kathy
Now Cooper will try his best
I have a friend here that is building a 56. He is going with shaved doors. I will pass this on. I think he might be at the point of no return though. He recently bought a 56 Fire Truck from some where in GA. Talk about a perfect cab and doors. Should be really nice truck. The truck only had 15,000 miles on it. I think he said it was a 292 Engine, so if someone is looking for a low mile engine. It's available. He palns to build the 56 on a early 90's Lincon Contintal chassiss..6166 Junkyard Dog wrote:Past exp.... shaved handles might look nice but not wise, have on my 56 and wish as never done power goes out your screwed so better put a back up in, next as hard it is to sometimes slam doors to get to shut, on my 56 one door cracked real bad where the handle was and used very little filler still cracked and welded plate to cover handle in past years have seen many rods cracked where the handles where daily driver no way,,, Trailer Queen go for it ,,,,,,,,, just myi
1966 F100 SWB 390/Toploader/Ford traction Loc
1997 F250HD 460 4X4
2004 RoadKing
1984 FLHS
1978FXE
1997 F250HD 460 4X4
2004 RoadKing
1984 FLHS
1978FXE
- therealjoeshmoe
thats why they make different poundage poppers.. you can get them from 20lbs on up... I got the 30 pounders which you need the heavy ones if you have a 71 lincohn but for our trucks a 30 pounder works great and wont damage your door... besides you should put a heavy strip of metal where the door poppers rest and you shouldnt have a problem with stressed metal...
shaved doors
i have shaved doors on my slick. i dont have poppers. i just reach through the air vent window and push on the handle. the door opens just fine. i also have no filler in the doors. everything was leaded.
if you do run poppers add a "pull wire" of sorts. a wire hidden that can be pulled and will release the door latch so the door opens if you loose power.
ill proubly just do that when i move on to one piece windows
'64 ford bbw custom cab short styleside bed
'32 ford 5 window body
'28 ford roadster pickup
'04 ford f150 crew cab short bed
blackagatha
Re: shaved doors
azratrod wrote:i have shaved doors on my slick. i dont have poppers. i just reach through the air vent window and push on the handle. the door opens just fine.
hahaha now that is a Ghetto Shave.... hope the Bad Guys dont watch you do that and see how easy it is.... Granted, it's just that easy on all (most) of our slicks. we just dont advertise it.
