Radiator Info Needed
Got a question for you all who have put 302 in '66 F100. Did you have problems with the hoses hooking up to the radiator? I seem to be dealing with hose diameter issues, as the thermostat housing is 1.5", the water pump inlet is 1.75" or so, but the diameter for the water necks on the radiator I have for 352(which I wanted to use) is 2". Do I need a radiator for later truck with 302 or what did y'all do about these hookups? Thanks in advance....
- FORDBOYpete
Just spitballing here...you might check into hoses for a later year with a/c & tow package, or camper package, or both.
Also, a good radiator shop should be able to hook you up with the correct sized hoses, they should have dimensions in a catalog...you just have to find a counter guy willing to take the time, that's the hard part.
Or just go with flex hoses, like these guys said.
Thanks again y'all. Will try for molded hoses with different size ends first, but if I have to I will settle for flex with different size ends. Like Pete said, gotta get back to driving. What started out as a simple power steering conversion became a cooling system upgrade, remove and clean/paint all brackets and pulleys, etc. (you know how it goes) and some other stuff "while I'm this far along" and days turn into weeks....Ready to be done with this and move along to the next thang.
The last time I bought parts at Auto Zone I ask the guy behind the counter for a 5/8ths heater hose and he brought me a 2in radiator hose.
That was the very last time I bought parts from Auto Zone.
Just thought I would share that while we were discussing hoses.
'01 F150 Lightning
490RWHP
Gas Mileage? What's that?
Jerry
490RWHP
Jerry
66camperspecial
What I do when looking for hoses is write down the sizes of the outlets and I form a wire in the shape and length of the hoses needed and the guys at the parts store let me browse and I can usually find a molded hose with the end sizes. Sometimes the hose is a bit larger and will need to be trimmed and I write down the numbers so I dont have to go through all the hoses again. I write the sizes on a piece of tape and put it on the ends of the wire I formed for the shape. Jeff
I had to use adapters. You can get the correct hoses for the 302 but then you will have to use the adapters to size up to the radiator.
Depending upon what transmission you use, you may end up with a 302 engine mounting further back than the original, so the adapters add useful length.
I kinda like the idea of using wire shapes for browsing the hoses at the store though.
- 6166 Junkyard Dog
Kathy
Now Cooper will try his best
