anybody unibodied a 64-66?
I thought I had run into someone doing a unibody 66 before but I cant remember where I found the thread. anybody on here know? I'm considering doing it myself later on because I want to shorten the bed and I figure why not take it a step further?
if anybody has experience with supporting the weld joint and stuff feel free to share. It's an idea I've been pondering but I wouldnt know where to even start with bracing and such.
1965 f250 long bed- 352ci 385rwhp
1993 toyota pickup- LT1 swap in progress
I enjoy crossbreeding.
Truckfarmer2
I do not know if this will work...since you will be shortening the bed sides, just leave the extra length and take it up to the door jamb area. This would require cutting the cab sheetmetal just behind the doors, but it would reduce the amount of added metal and body filler. Just a thought.
61 f100 shortbed unibody
if i was doing a twin i uni, i would cut the uni behind the seats and at the roof seam above the back window, shorten the wheelbase and weld the bed and window section to a 65/66 2wd cab.
that way you would not need to fight with cab mounts and steering mods.
Garbz
It'll at least get boxed. knowing myself I'll probably start off just boxing the frame, and end up with an entirely redone frame. I'm gonna need to move the back half forward anyways to line up the wheels and such. It's gonna be a job, thats for sure. But what's the fun in hotrodding if you do everything easy?Truckfarmer2 wrote:My suggestion would be to box the frame so it won't flex anymore. If the frame flexes, the bodywork welds and filler would crack.
When I was doing the frame for my toyota, I was just gonna move the gas tank to the rear, swap to a bigger rear and re route the gas lines. I ended up doing a full 4 linked rear end with coilovers, and front converted from torsion bars to coilovers, which I had to have custom control arms made for.
my whole thing behind this is to keep the body lines of a 64-66 bed while still having a unibody. rather than it just looking like a factory unibody.ICEMAN6166 wrote:if i was doing a twin i uni, i would cut the uni behind the seats and at the roof seam above the back window, shorten the wheelbase and weld the bed and window section to a 65/66 2wd cab.
- FORDMANLCRACKEL
Mac are you talking about taking a 64-66 wide bed and 64-66 cab and making a uni from it, not i uni bed from a unibody and putting it on a 64-66. If you are talking about the first part i have thought about it, and might do it one day, but i dont think it will look right.
Lonnie
Lonnie
- ezernut9mm
needs more cowbell. loljwh f-100 wrote:I would think if a guy connected a long bed to a 115" shortbed truck the a$$ would be too big. I would think the best combo would be to add a 64 - 66 (129") long bed to a 62-63 (120") long bed truck..
Heres my photochop of my truck.
that looks pretty cool really
exactly what im talking about.FORDMANLCRACKEL wrote:Mac are you talking about taking a 64-66 wide bed and 64-66 cab and making a uni from it, not i uni bed from a unibody and putting it on a 64-66. If you are talking about the first part i have thought about it, and might do it one day, but i dont think it will look right.
Lonnie
I may shorten the bed in the process. the long bed gives me extra material to work with so there's the option open.jwh f-100 wrote:I would think if a guy connected a long bed to a 115" shortbed truck the a$$ would be too big. I would think the best combo would be to add a 64 - 66 (129") long bed to a 62-63 (120") long bed truck..
- Johnny Canuck
Garbz
Yes it is in York, Bought by a member Jim Fiurst (flag Truck at SS06). He planned to finish it.
I have my old drive here with many pictures on it of the build from the frame up. Chassis is set up with all new parts N pieces and for a 385 series engine/C6 combo.
I had a lot of time redoing the cab and making the uni split bed. Also has a full over head center console that housed the radio, lights, power outlets and a flip down DVD player.
Garbz
Garbz
65-66 uni
My buddy and I were down in Omaha,Ne about 1 year ago buying a lwb 65, I got into a conservation with the bodyshop owner and he said that he had just welded up a 65 or 66 for a young guy down there and that it looked really cool. I've been kicking around the same idea for my 66 but it's a very straight slick and I don't want to chance it not working out. But I do have an old 65 short and a extra long box....mmm maybe!! Later Randy
Looks great! How did you get the lines to match up? I would guess the line on the back of the front door would be lower then the front of the rear door.Garbz wrote:Yes it is in York, Bought by a member Jim Fiurst (flag Truck at SS06). He planned to finish it.
Garbz
This type of work really interests me. My Dad has a '42 international sitting behind my garage that has given me the idea of building a "delivery".
Jason
Beer will change the world.
I don't know how but it will.
