FordBoyPete Update
Johnny Canuck
FordBoyPete Update
Post by Johnny Canuck »
got an email from FBp today. here's what he's been up to..in His words;
I attached a few examples including a motion graphic on how a Napier Deltec T-18 Series engines work, picture a concept of two pistons heading towards each other in 6 common cylinders, with a center combustion chamber in a common engine block, off of 3 separate crankshafts spaced @ 120 degrees apart, to create a two stroke 18 cylinder "Y" Block engine
006 Vee Drives transmit power from engines to propellers thru prop' shafts. They are tucked in the front of engine bay & must be "swung out & up", but can not be "tag lined" I am guiding a Vee Drive out and it is swinging out.
007 Okay now the opposite & equal motion, it is coming swinging back at me. I evacuate the area, or else I'll be whacked by it.
011 we are replacing the engine bay hatch cover & Jim Vough is on the after deck holding a "tag Line" to prevent the cover from swinging like the Vee Drives do.
You think finding good Slick Parts is rough. . . . Try finding parts for something from the same period where only 16 or 17 were ever built, and people were trying to sink them or blow them up. . . . . . . ya know?
Ford4jack
Post by Ford4jack »
That is a cool design I looked on You Tube after reading the post by FBP a while back.
Be interesting to see and hear one up close :)
Edit # 2 scratch edit # 1 Me be thinkin in the T zone :roll:
Phil
Post by Phil »
bet they sound awesome
Should call this guy. I bet his are lighter :)
http://www.craftsmanshipmuseum.com/Tomlinson.htm
jakdad
Post by jakdad »
Gonna put one in your Slick? :lol: :lol: :lol:
Jim
I also notice the name Napier on the valve covers. They made alot of strange configuration aircraft engines during WWI.
Slick Fan
Post by Slick Fan »
Those are some funky engines. Looks like the project is plenty-o-fun, though. :cheers:
64 f100
Post by 64 f100 »
Wow, is all I can say. Sure would like to hear it run. What kind of torque and horsepower?
DCarr
Post by DCarr »
Napier has always built "different" engines. In ww2 they built sleeve valve aircraft engines-made a LOT of power but had some reliability issues.It powered the Hawker Typhoon & Tempest.
DCarr wrote:Napier has always built "different" engines. In ww2 they built sleeve valve aircraft engines-made a LOT of power but had some reliability issues.It powered the Hawker Typhoon & Tempest.
You are a aircraft nut too huh.
DCarr
Post by DCarr »
Yeah, just about anything that is powered. I also attempt to fly RC airplanes & helicopters.Can't afford the real thing.
DCarr,
I fly RC too, just bought a GWS Slow Stick for a "knock around" parkflyer, will stiffen it up a little. Have an E-Flite SE5a ready to fly. I mostly prefer scale/sport scale but presently lack the space to finish any projects or start new ones - stuck temporarily in ARF land, lol. I also have been all E power for about 6 years now. I build mostly WWI aircraft.
This is going on the SS with a 3s 1500mh pack and a 12x6 E-flite SF prop.
http://www.graysonhobby.com/catalog/pro ... cts_id=703
FORDBOYpete
Post by FORDBOYpete »
Jim,
Nah I'll stick with my 385 series for now, thank you very much.
Rich,
You can hear one run. They're on You Tube, just search Napier Deltic 18 cyl engines. They're still used
in Locomotives & watercraft in England & Europe too. They are a "hoot" & get revved qwickly being a 2 stroke turbo and all.
I am not sure of the torque rating, they are turbo charged and make a rated 3600 hp each @ 2150 RPM,
so we've 7200 applicable Horsepressure. The boat will run 70 knots fully loaded (ordinance, crew of 12, etc. ).
It displaces 84 tons, is 80+ ft O/A from bow stem to the transom/stearn.
We are setting our Napiers up to run via PCM or "dreaded" computerized performance control module.
We want enhanced performance & efficiency. We are into all that sort of stuff. One of our crew developed
laser guidance systems after he was discharged from service where he worked on avionics systems
& helicopters back in the day.
It's great to see all the interest in this.
We are also restoring a 1940's Grumman TBF Avenger off the bottom of Lk Michigan,
We have, display & maintain a F-14B. Our Tomcat last flew in Iraq late '03 & flew off the Kennedy in '02 flying Iraqii
no fly zone patrols there. We have a T-33 that may have been one Don Mallick flew during Little Joe Project,
Ring Chute testing on Mercury Capsules & Monkey Drops during early days of NASA o the Atlantic Range
from Wallops Is. South etc. We're also trying to get a Douglas Dauntless SBD-5 Dive Bomber for static display here.
Our Museum's was a NAVAL AIR STATION training facility from early '42-mid 46. Duntless SBD's centerpiece
to the facility which introduced Florida to 1,000s of people who would not otherwise ever come here, but
now have moved here to retire etc. etc.
Our crew is a very diverse group of fairly accomplished individuals we're actually all volunteeers too.
FBp :cheers:
Change is the Only Constant
DCarr
Post by DCarr »
Most of my planes are fuel. I also do mostly ARFs do to time issues ,but I really prefer to build up kits when I have the time. I have 6 helis-3 are electric-from beginner to 3-D. MY son in law is a Global & Tower distributor so that's where most of our stuff comes from. My current knock around planes are 3-D stunt-1 electric & 1 powered by a 91 4-stroke.
DCarr
Post by DCarr »
To FBP- it's nice that you are in a position to volunteer doing something that you enjoy. In SanDiego, we have the SanDiego Aerospace museum, a railroad museum, and a transportation museum all with volunteer restoration teams. It's going to be hard for me to choose which one to pursue. Thanks for the info----David.
FORDMANLCRACKEL
Post by FORDMANLCRACKEL »
FORDBOYpete wrote:fyi.gif
Jim,
Rich,
FBp :cheers:
FBp emailed me some photo's. I put them in a folder on my album at Photobucket i thought you fellow's might like to see them.
http://s275.photobucket.com/albums/jj31 ... RDBOYpete/
Here is a web page for more info.
http://www.ptf3restoration.org/
Feel free to check back any time i will be adding photos as Pete sends them to me if it is alright with Pete.
Lonnie
jakdad
Post by jakdad »
Haven't seen a PT boat in many years. I am so proud of you folks and the Scouts for undertaking this task. Best of luck to you all.
One question, I may have missed this in an earlier post, but does it still have the Allison engine?
Thanks,
Jim
Jim
FORDMANLCRACKEL
jakdad wrote:Haven't seen a PT boat in many years. I am so proud of you folks and the Scouts for undertaking this task. Best of luck to you all.
Thanks,
Jim
The PT boats WW II had 3 V12 Packard engines. Boat and engine built in the USA. The PTF 3 that Pete is working on came with the 2 stroke engine that JC posted. Boat and engine built in Norway.
Lonnie
jakdad
Post by jakdad »
Jim
FORDBOYpete
Jim,
Entirely different deal.
The only similarity between WWII PT boats & Viet Nam era PTF Nasty Class we are doing is 1st two letters "PT".
Nothing else is the same. PT's of WW II are as noted gassers, smaller & lighter & plywood & slower and much much
more dangerous plus not loaded with ordy & technology etc. Also the PTF Nasty Class didn't carry torpedoes either.
PTF 1 & 2 were Gassers like WW II boats, but they were aluminum hulls & may have been built by Higgins.
Not sure about that, but they were niether Norwegian nor Trumpy built although were still called PTF Nasty class.
They were not double planked mahogany boats like #3 through 10 or 12 are. In fact boats through #20
may have been mahogany planked, but only 26 were built in all and not all are the same although they are similar.
There's a recently completed WW II PT with Packards running out of Oregon I think. There is a website on that boat.
Perhaps it was PT 368 :hm: I will check
Okay, it's at http://savetheptboatinc.com/
jakdad
Post by jakdad »
FORDBOYpete wrote:Jim,
Thanks FBP, Great site. Someone in Baytown has one of those. Haven't been down there in years and do not know what he was going to do with it. Now that I have read your post, I'm not sure which type it is.
Jim
