I just purchased a 85 f150 4x4 with a 300six and a auto trans.
The p/o cut the pin in the rear diff due to the spider gears were stuck to the pin.
No tag on rear end. Looks like a dana but not sure. The ring pinion and side gears all look good.
Would like to find a set of spider gears and pin to install.
What years will interchange? I have a rear diff assembly out of a 78 4x4, and was wondering if the spiders were the same? Or maybe just swapping the whole axle if it would work.
Only problem is not knowing gear ratio.
Thank for any and all help.
Wes
rear end
ghostflamed66
rear end
64 4x4 with tilt front end
65 f100
66 f100
66 ranger
66 fairlane 500
65 f100
66 f100
66 ranger
66 fairlane 500
Garbz
Wes
Look at the Data plate on the door jamb it will tell you the letter or number of the axle code.
The axles are listed in a Chilton/Haynes manual or on line.
Typical gear set is 3.73s for the 300.
Your rear should be a common 8.8 rear. The bronco 9 inch may not bolt in and be of another ratio. Bad for a 4x4.
Garbz
Garbz
