Rear fuel tank installed (pic warning)
Jason, you should definitely put that in the "Hints" section. Nicely done!
jecsd1
Post by jecsd1 »
OK guys I started a thread in the hints and tricks. Read it and let me know what I missed. I have the body off right now so now's the time for pics. Keep in mind though that I haven't finished the filler or fuel door.
Fanatic
Post by Fanatic »
Jason, I just measured up my factory injection fuel pump.
Its a 96 truck pump Ford #F6TU-9A407-CB. I picked it up cheap on E-bay years ago for my truck,but stuck with the in-cab tank for now. Here's the specs.
9" depth needed
3 3/4" hole in top of tank
would probably have to make a gasket and screw it to top of tank since Ford used that locking ring to hold it in
Does this sound like it would work with that tank?
I can take pics if needed.
Tim
jecsd1
Post by jecsd1 »
Tim,
Hope these help. It looks like you might be good on width but the tank's not deep enough. The company I got this from makes a universal in tank injection setup. That may be an option for you. Good luck. Let me know if I can help further.
[albumimg]4996[/albumimg][albumimg]4995[/albumimg]
Fanatic
Post by Fanatic »
That says it all Jason. Thanx and nice job on that install.
