I know its not a slick,but it is a ford, and I do own a great little 66 slick. I need my big truck truck back on the road.
Question is ?
Is the steel spacer plate thickness the same on the automatic and the standard ,it goes between motor and bell housing.
Thanks for any help
Truckerdaddy66,New Caney,Tx.
Transmission swap on a 86 f250 diesel
truckerdaddy66
truckerdaddy66
Garbz
The adapter should fit the C6 and the Manual five speed and four speed big block bell patterns.
Most are not familiar with the 6.9 or the 7.3 IDI and the trans adapters. Ford did not make a bell housing specific to Internationals pattern so they used the adapter to fit the 385 series engine to transmission pattern all ready on hand.
PM Number Dummy on this board and ask for the part numbers for each the auto or manual he can give you any differences.
Garbz
Garbz
