Woodgas unit ready for testing
Been working on a woodgas unit to power a lawn mower with Y'all
I have it to the testing point now and I'm just waiting for the wind to calm down. Should be able to fire it off this afternoon.
Went with charcoal and fiberglass for a filter and an oil bath filter after that.
The blower is for starting it and once the gas is going its removed and a hose is put on to the engine.
I'm not sure how well the blower is going to work for testing.
I dont think it is going to pull as much air as a lawn mower engine will but it should give me a general idea on the gas quality.
[img][img]http://i510.photobucket.com/albums/s345 ... gas003.jpg[/img][/img]
Well it worked
gas quailty seemed good it lit instantly and the wind could not blow it out.
It did have a lot of moisture in the filter but I am going to make a wood chip hopper to increase its capacity and catch moisture.
It will be a funnel shaped hopper inside a mushroom shaped outer shell.
modeleh
The idea behind this is to inject air into a fire to get it hot enough to break down the molecules in wood that sits on top of the fire.
The depth of the coal bed under the fire burns out the tars etc.
After that its cooled,cleaned and ready to burn.
That's the idea behind it anyway.
This was used some in europe during ww2 when there was no gas.
There's quite a bit of history behind this fuel and its used for electric power generation etc in some remote places.
All and all it was a good first run the wood chips fed smoothly cooler condensor tank worked well etc
Hopefully I wil get it all dialed in and be able to mow with wood this summer
Hey if nothing else I will have a fancy marshmellow roaster
modeleh
That is really cool. Are you able to burn most any mulched up wood products, ie pine needles, cones, small branches, etc.? How dry does the fuel need to be?
It looks like you could pipe that gas into a burner plate with a bunch of small orifaces to make a water heating boiler. You could then pipe the hot water into heat registers in the shop.
A friend of mine has a used oil boiler to heat several outbuildings at his place this way, and we are looking at alternatives due to the increasing difficulty of getting used oil in large volumes. We are currently thinking about making a wood pellet mill, but this woodgas thing might be simpler.
good job...
i have built many 'devices' in my head
but few of them actually make it to the shop
hope to see you at SSIV with one powering your truck !
glad it is working for you
- therealjoeshmoe
Here's a site that explains how the gas is made and what its made of in the diagram section
& I think theres some stuff about fuel types also.
The project design file has instructions for a basic woodgas unit but it would not open for me today
I remember reading that this gas was used to power streetlights in some city's years ago
so it should work for a water heater as far a plumbing it around and such.
But this gas is poisonous also.
I would think for heating this would be a high maintenance system but there's a lot of ideas to be found on the Internet about this stuff.
I just went looking for its use for engines but I saw a lot of commercial applications for it's use
http://www.fluidynenz.250x.com/
Aww Joe it wont blow up..............I hope
after all I need to stay alive so we can make it to slickstock to meet Y'all
