im thinking of putting a 4 post lift in my garage need to take out 3 rafters and make it into a cathedral ceiling so i can put the 55 on top and 65 on bottom any one have this kind of set up in a standard 8.5 foot to rafter high garage
John
4 post in garage
4 post in garage
2) 55 f100's
2) 65 f100's
and all the other ford trucks my wife doesn't know about!!
2) 65 f100's
- ezernut9mm
johnny, check out garageforums.com. it's a small site, but only covers garages as a topic. there are some threads about lifts. you might get some ideas.
3ontree66
Put son's chebby on lift,raise it the required amount,scab 2x4s to whats left of rafters for support,lower chebby-voila- you're all done.
66 F100 300 4 speed! Power steering!
78 Kawasaki KZ650
75 Yamaha XS 650 x 3.
82 Suzuki GS850G.
78 Kawasaki KZ650
82 Suzuki GS850G.
BackyardRest
I did something similar here:
Higher ceiling on one side to accomodate the hoist although obvious not a 4 post. Same idea tho.
If you plan on parking one up top the 4post is the way to go. Usually the trusses have to be engineered but may be doable to change. Might want to get an expert to take a look-see
