losing faith in humanity - more 429 woes (editted)
- Hoofbeat Racer
Well patience prevailed, I posted some ads and got a few responses. Looks like a I found another 71 429 with DOVE heads and a C6 all running for 500 bones. Only downside is it has a 2bbl. I thought only 2 bbls were available on base 69 and 70 Thunderjets. Anyway, I am supposed to pick it up next Saturday. Had a great talk with the guy after getting screwed over last week. I can't believe how quick I found another one. This one seems to have a few more scruples. Will keep you all posted on this one
Last edited by Hoofbeat Racer on October 31, 2009, 5:52 pm, edited 3 times in total.
Mark
This deal sounds better already.
- 6166 Junkyard Dog
Good Luck, Mark,,
for you ,, did not get to post on last problems you had so I hope works good for you,, I know I have been how can I say shafted by some especially since they we see we are in the business they will raise the price to us while in return sell to one of there buddies way cheaper or give it to them ,, had once a pair of ranger seats wanted to sell to me wanted 300.00 then when I said no, found out few days later that he gave them away right here 25 miles from us this was from another site that will keep to myself or some of them on e-bay does it to you,, Good Luck Mark...
Kathy
Now Cooper will try his best
- 66fordtrucknut
- Hoofbeat Racer
That's kind of the plan Tom. Although I feel quite secure in my job, shelling out for the stroker may not be the wisest thing to do right now. Somehow mortage and family take precedence in these uncertain times. I need a new block anyway so I figgered if I could find a decent 429 that was intact, I would run that for the summer and plan on building the stroker over next winter. This 429 stock with the 2 bbl is 320 hp, I can throw an intake and carb on and I need new headers anyway so I should be able to get close to the 400 mark. Then when I am done, I can easily flip the DOVEs and dump the C6 too. Thanks for the support fellas.
Mark
- robert porterfield
I kept meaning to read this thread.
Glad things are working out for you Mark, you deserve it!
- Hoofbeat Racer
Made the road trip yesterday, 7 hours of driving in somewhat of a blizzard, lost track after over 30 cars in the ditch. Picked up my temporary engine. It all appears to be good. Guy was a really nice. Engine was everything he said it was. I'll throw some gaskets on and check bottom end and she should give me a little fun this summer until I can afford to build my stroker. 500 bucks I am not complaining too much.
Mark
- Hoofbeat Racer
They just used the parts on hand with out changing the # around each year. Ford only changes # when they make a change in the part. That's why D3VE heads are so easy to come by they used them for years without making a change.
Nice to see you got an early set up. Do you know what it came out of originally?
Tom Williams
Good looking engine Mark. I had one in my 71 Torino GT with a C6. I recurved the dizzy a tad, used a 4bbl carb from a 69 Lincoln 460, 2 1/2" duals with turbo mufflers. It was a great setup, it ran neck & neck with an original 70 Torino Cobra with a factory 429 & 4 speed.
- Hoofbeat Racer
I would like to retract everything I had said when I started this post. I think I need to start adopting the mantra of &%$$# or be &^%$#%$ed
Last night I took the engine apart that I had bought last spring. I put it in my 66 for the summer so at least I could drive it. It ran ok but there were quite I few little issues. Now I am stripping what I need and going to toss or sell the rest. Namely, the 71 DOVE-C 429 heads. Well check this out, I never seen this as they were fully assembled (rocker arm blocking my view) but the seller assured me that he just put fresh head gaskets in and the valve faces looked good. Compression test did verify this. What he failed to tell me after I drove 150 miles to pick it up was this
I have nobody but myself to blame and my supposed trust in like minded hobbyists. I assure you all, this will never happen again. I just am livid right now.
Mark
