trans shifting problem
ghostflamed66
Post by ghostflamed66 »
Need help on my 85 f150 that i just got.
It has a auto trans in it. When i am driving it will not shift from second to third until i reach around 45 mph, and will shift between third and second gear when 35 to 40.
Is there a ajustment for this, or somthing else.
The fluid is full.
Thanks,
Wes
64 4x4 with tilt front end
65 f100
66 f100
66 ranger
66 fairlane 500
is it the AOD tranny?
sounds like the shift down cable might need adjustment
try this link...this guy will help explain
http://www.youtube.com/watch?v=6L3hNzxdiYw
ghostflamed66
The truck has a 300 six in it. It is a carb. engine. Not overdrive.
Thanks for any help .
That was a good video about AOD trans.
Wes
65 f100
66 f100
66 ranger
66 fairlane 500
Fanatic
Post by Fanatic »
If it has a vacuum modulator.that is the culprit. It controls the 2-3 shift point. Some screw in and some are held in like a speedo cable. There is a little shaft inside when you remove it, don't lose it or forget to put it back in there.
Tim
